V belt size????
   / V belt size???? #1
watersteps
David Bradley 917.5121 Terramite T5C
Hello,
I just purchased a David Bradley 917.575121 with a Wisconsin ACN engine. The tractor has 3 belts which I would like to replace at sometime. the belts are 530H, 529H and 7843MI per the manual. Can anyone tell me what size belts I need to replace these belts??
Thanks
   / V belt size???? #2
Hello,
Thanks
No worries,
All V belts are metric so its not a problem find a V belt reseller like NAPA that can measure the belts for you using a V belt gauge and they will provide you the proper new V belts quickly.:thumbsup::):drool:
   / V belt size????
The problem is the belt I have is a 1/2 inch belt this pulley takes a 5/8 belt.
I have been using it and it works fine but, I have decided to replace this Wisconsin ACN with a Briggs or Tecumseh with a recoil starter.
I will be selling the Wisconsin or trading it for a 8 hp Briggs if possible.
Thanks for the info.
   / V belt size???? #4
On your V belt spend the extra money a get outdoor or equipment rated belts. They are meant to have a back idler so they bend and they are fabric covered. Industrial belts are meant to run inline and around larger sheaves.
Craig Clayton
   / V belt size????
Thank you, good advice.
2003 FREIGHTLINER FL80 DUMP TRUCK (A51406)
2003 FREIGHTLINER...
3-Point Hitch Root Grubber - Heavy-Duty Tree and Stump Puller for Tractors (A52128)
3-Point Hitch Root...
Mitsubishi FG35 Forklift - 8,000lb Lift Capacity, LP Gas (A52128)
Mitsubishi FG35...
2012 Hyundai Sonata LIMITED (A50324)
2012 Hyundai...
2013 Isuzu NPR Eco Max Box Truck (A47384)
2013 Isuzu NPR Eco...
2008 CATERPILLAR D6T LGP CRAWLER DOZER (A51242)
2008 CATERPILLAR...
