UTV Tires
/ UTV Tires #11
On my sport side by side I run Carnivores - very tough tire, decent on the asphalt and great in the woods on a variety of WV trails from rock to mud.
On my Mule Pro (bigger utility machine) I have Pitfall growlers. Excellent in the woods and seem like they may last a LONG time. 1200 miles so far and mostly on rock, and asphalt and look new. They also seem to carry a heavy load well, they are expensive but if they last and work well I can live with the little extra cost.
/ UTV Tires #12
Tusk Terrabites are good, tough, DOT-rated radial tires. I've been happy with them in the Paul Bunyan that has a lot of rocks, roots, loom, hard pack, and then more rocks. I did cut a sidewall on one tire in the last 3,000 miles. Anyway, Terrabites are what I run in the summer on my UTV. Also, don't buy bigger wheels and tires for whatever you get. Doing so is hard on the suspension and wheel bearings.
I run Commanders with about 150 studs in each tire in the winter.
I disagree imo going up one tire size ie a 26 to a 27 requires no adjustment and won't hurt anything, go up two sizes might have to adjust the clutching if it's belt driven which is what will take the most abuse from a tire upgrade imo. Upgrading rims and tires on my pioneer 500 and wolverine X4 by one size was one of the best upgrades I did.
/ UTV Tires #13
I agree with Jeff - I would not worry about going up a tire size or two. We been doing it on tons of machines and of the ones I repair I have not noticed any change in bearing wear - most wear we see is from mud or extreme use. Most issues I deal with is guys crashing into stuff......
/ UTV Tires #15
Suspension seats, and a mesh rear screen to keep dirt from flinging into the cab area were the two best upgrades I did followed by a Dalton Clutch and an IR sensor on the belt so I know when it is overheating.
Anyway, RZRs live different lives. I wouldn't ever want to put even more unsprung weight on the twiddly bits as the increased wear and leverage leads to more failures out on the trails.
/ UTV Tires #16
I see your point and an IR sensor for the belt or clutches would be a great add on, I remember how hot my primary clutch and belt got when I long tracked one of my old snowmobiles, a sxs is 3 times the weight but less resistance most of the time, anyways I could definitely see the importance of monitoring belt temp on it.
/ UTV Tires #17
I changed to the Tusk Terrabites on my Yamaha Rhino from the factory tires after 12 years of use. I did go up in size a little. I got the Terrbites due to tight tread pattern for hard pack and paved roads... they drift in sand real bad which is a lot of what I have on our 5400 acre hunt lease... there will always be a trade off some where
2022 CAT 289D3 (A60462)
2022 CAT 289D3...
2017 John Deere 8245R (A60462)
2017 John Deere...
2019 Ligchine Spiderscreed Concrete Screed (A59228)
2019 Ligchine...
2013 Ford Focus Hatchback (A59231)
2013 Ford Focus...
2024 MACK GRANITE GR46F DUMP TRUCK (A59823)
2024 MACK GRANITE...
2006 Columbia Medical Transport Electric Utility Cart (A56859)
2006 Columbia...
