UTV accessories
/ UTV accessories #61
I got my trailer with my SxS in mind. It can carry the SxS and the SxS can pull the trailer. 77"x14', with 5k lb axle.
I need to widen a couple of spots to fit the trailer all around the property.
The SxS is a bit heavy for its size due to it being EV.
It came with the receiver. I use the same hitch i use on my truck.
/ UTV accessories #62
When it's time to replace the batteries, if they're lead acid, look into lithiums. Much lighter, no watering.
/ UTV accessories #64
The most used accessory on my Honda Pioneer is the front mounted two inch hitch receiver. I use it for spotting trailers mostly, but it can also double as an attach point for my winch line when using a snatch block.
For a dome light, I found some roll bar mounted velcro lights so that I didn't have to run wiring...
Also found some velcro roll bar mountable hand grabs that my much shorter wife needs to get in and out...
/ UTV accessories #65
For day-to-day work, the most underrated add-on has been a Polaris Ranger Midsize 570 tinted windshield. Cuts glare, keeps dust out, and makes long hours way more tolerable. Also added a small overhead switch panel for lights, sprayer pump, and a backup alarm. Didn’t realize how handy that would be.
/ UTV accessories #66
I have a glass windshield for my Polaris Ranger. Only use it in the winter. I take it out during the warm dry season. The thing is heavy, but should never need replacing due to scratching or fogging.
/ UTV accessories #67
Kubota RTV-X1100C. It came from the dealer with the Boss 6-way plow so I won't count that.
I got an extra pair of worksite tires for the rear, and a set of diamond pattern chains - no removing/remounting chains; just swap out chained for non-chained tire pairs.
I added a heavy gauge wire and Anderson Power Pole connector to the battery. All my off-property vehicles have these so I can jump easily, as well as quickly/conveniently run water pumps, sprayers, winch, chargers, etc.
I added a Farm Boy 3-point hitch to the rear. Good for a york rack, lightly loaded pallet forks, garbage can lifter, middle buster; anything under 400 lbs reportedly.
Added front and rear LED auxiliary lights as well.
Cattle Feeder (A65640)
Soil-Max HD Cart (A64126)
Soil-Max HD Cart...
Steel Blasting Shed (A62679)
Steel Blasting...
2008 PROCO 130BBL (A65643)
2008 PROCO 130BBL...
2021 Kubota MX6000 (A62177)
2021 Kubota MX6000...
(4) ASSORTED TIRES (A62613)
(4) ASSORTED TIRES...
