UTV accessories
/ UTV accessories #61
I got my trailer with my SxS in mind. It can carry the SxS and the SxS can pull the trailer. 77"x14', with 5k lb axle.
I need to widen a couple of spots to fit the trailer all around the property.
The SxS is a bit heavy for its size due to it being EV.
It came with the receiver. I use the same hitch i use on my truck.
/ UTV accessories #62
When it's time to replace the batteries, if they're lead acid, look into lithiums. Much lighter, no watering.
/ UTV accessories #64
The most used accessory on my Honda Pioneer is the front mounted two inch hitch receiver. I use it for spotting trailers mostly, but it can also double as an attach point for my winch line when using a snatch block.
For a dome light, I found some roll bar mounted velcro lights so that I didn't have to run wiring...
Also found some velcro roll bar mountable hand grabs that my much shorter wife needs to get in and out...
/ UTV accessories #65
For day-to-day work, the most underrated add-on has been a Polaris Ranger Midsize 570 tinted windshield. Cuts glare, keeps dust out, and makes long hours way more tolerable. Also added a small overhead switch panel for lights, sprayer pump, and a backup alarm. Didn’t realize how handy that would be.
/ UTV accessories #66
I have a glass windshield for my Polaris Ranger. Only use it in the winter. I take it out during the warm dry season. The thing is heavy, but should never need replacing due to scratching or fogging.
/ UTV accessories #67
Kubota RTV-X1100C. It came from the dealer with the Boss 6-way plow so I won't count that.
I got an extra pair of worksite tires for the rear, and a set of diamond pattern chains - no removing/remounting chains; just swap out chained for non-chained tire pairs.
I added a heavy gauge wire and Anderson Power Pole connector to the battery. All my off-property vehicles have these so I can jump easily, as well as quickly/conveniently run water pumps, sprayers, winch, chargers, etc.
I added a Farm Boy 3-point hitch to the rear. Good for a york rack, lightly loaded pallet forks, garbage can lifter, middle buster; anything under 400 lbs reportedly.
Added front and rear LED auxiliary lights as well.
2013 Ford F550 Bucket Truck w/ Jib (A62613)
2013 Ford F550...
2003 VOLVO G720B MOTOR GRADER (A66091)
2003 VOLVO G720B...
40ft High Cube Shipping Container (A65583)
40ft High Cube...
2010 PETERBILT 384 (A65643)
2010 PETERBILT 384...
Mini Skid Steer (A60352)
Mini Skid Steer...
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A61307)
2-Row Peanut...
