UTTF weights?
/ UTTF weights? #1
Steve_Miller
Nova Scotia, Canada
2006 Kioti CK30HST
I have a chance to buy some Gulf UTTF 80W. Are there different s weights to UTTF? I thought it was universal fluid meaning it would work in most brand of tractor.
Thanks Steve
/ UTTF weights? #3
You can get tractor hydraulic fluid in different weights. Some is just hydraulic fluid and some is intended for use in the transmission as well. What you want depends on what your tractor wants. If you have an HST transmission go by manufacturer recommendations.
/ UTTF weights?
I agree but most UTTF / UDT fluids from what I’ve seen don’t put the weight on the label. For example, what is the weighting of Kubota UDT / UDT2 fluid? This oil says it’s compatible with Kubota UDT fluid which I’m assuming would be fine for my Kioti (other than it may make a cringy face if I used it 😂)
I never really knew the weighting of these fluids, thought they were all compatible. Thanks for any info.
/ UTTF weights? #6
Most UTF will be labeled some were in there data sheets with a weight usually it will be a multi weight,
such as 10-30 or 10-40 the higher end fluids may be 5-30 or 5-40.
I hadn't noticed one with a straight 80W which in gear lubes is about the same viscosity as 30 weight motor oil.
2019 HYUNDAI V12530152-AJS 53' 102" T/A VAN TRAILER (A59912)
2019 HYUNDAI...
Tennant 7400 Compact Industrial Floor Scrubber (A61572)
Tennant 7400...
2005 John Deere 7420 (A60462)
2005 John Deere...
2015 K and K Systems Towable Solar Arrow Board (A61572)
2015 K and K...
John Deere 5420 Tractor with Quicke Loader (A64047)
John Deere 5420...
2023 Cat 259D3 Skid Steer (A64194)
2023 Cat 259D3...
