Utility Trailer Big Tex
/ Utility Trailer Big Tex #1
Leemac
Central Ohio
Ford/NH 1320 HST FWD
I'm looking at utility trailers Top Brand,Big Tex, & Quality 6 by 12ft actually about 77 inches wide by 12 ft. My question is, I can get a heavy duty gate on Top Brand and Quality and on the Big Tex (which I like the best) only comes with standard steel mesh Ramp Gate. One of the heaviest items I'll use trailer for in L/T and Loaded 50 gallons sprayer for a total of approx 1200 lbs. In your opinion will the Big Tex Ramp/Gate take this weight. The Salesman says no problem, gate will take up to 2000 lbs. Just want to ask for other opinions. Appreciate any comments.
/ Utility Trailer Big Tex #2
I've owned a Big Tex Landscape trailer for years, I do general contracting..residential work and the trailer has gotten alot of use.
This a 7000#GVW tandem axle, 7'x12' , had them put brakes on all 4 wheels, and load range D tires, and a steel deck as extras from the factory...by the way.
The gate has proved to be pretty strong, but can you clarify what you will be loading and it's weight so I can give you feedback??
Regarding your salesman saying 2000#, hmmmm, that seems like a little optimistic. That square tubing is thin wall, like around 1/16". And the mesh is just expanded metal lath type material, so any kind of point loads (like wheels would need a pc of plywood or planks soas not to bend the mesh...
Let me know a little more about what you intend to load on the gate so I understand what we are discussing??
Runk
/ Utility Trailer Big Tex #3
I had a BigTex landscape trailer with the mesh gate and it handled my 4110 without any problems. /forums/images/graemlins/smile.gif We now have a BigTex car hauler w/dove tail & slide out ramps that I really like. /forums/images/graemlins/cool.gif
/ Utility Trailer Big Tex #4
I have a big tex car hauler.. 2x8 wood deck, and heavy duty angle iron ramps. The trailers I see with expanded metal gates are usually the 'yard work'/ landscape units. Still.. see if you can get a HD gate/ramp..e tc.
Soundguy
I would be loading a Lawn Tractor (600 lbs) and a two wheel 50 gal sprayer approx (600 lbs) attached to tractor. So the load would on 6 wheels. Thanks for your comments.
/ Utility Trailer Big Tex #6
I've had a 6'x12' Big Tex, model 35SA I think, for three years. I drive a 700 pound garden tractor on and off and the metal mesh is showing some deformation, but not enough to be of concern. With me in the seat it's 900+ pounds spread across four wheels, so 1200 pounds across six wheels shouldn't be a problem.
/ Utility Trailer Big Tex #7
I bought a PJ trailer with the mesh gate and load my nearly 2000 lb Kobota on it.
What I did, since the supports on the mesh were NOT under where the wheels would go, was cut some 2x2x1/8" angle and welded it right at the centerline of the tires. One can of black Krylon later and it looks GREAT. No sagging. See pic.
Ron
Dk45 Jeff-
Thanks for reminding me of another 200 lbs.(me). Now a total 1400 lb. I think if I can get the right price, I'll go for it . If there starts to be any problem, I'll just re enforce gate. Many thanks to all for the replies/advice.
/ Utility Trailer Big Tex #9
We have a couple of trailers (not Big Tex, but similar ramps) that we haul JD 455 mowers on. Not sure of the weight of the mowers, but they're 23HP watercooled diesels, 60" deck. No problem with the ramp at all. Your 1400 pounds will be spread out quite a bit, as the mower and the sprayer trailer won't be on the same set of wheels?
/ Utility Trailer Big Tex #10
Yes, as the replys above are saying , with some remedial care to take care of the mesh to keep it from distorting that setup will work good.
I think the Big Tex product is pretty good and we have a bunch of different trailers here now for comparison.
Out here in California the trailer dealers sell them at fairly high prices.
Best,
Runk
/ Utility Trailer Big Tex #11
I think your biggest problem is going to be driving up the trailer from the tailgate, if you have a belly mounted mower. I have a 5 X 12 tandem and you have to park just right to load. or else you have to get off and man handle the thing in there. it only takes a little hump on the gate to high side the tractor. Gary
/ Utility Trailer Big Tex #12
tires make a big differnce here too. Although trailer tires are what they always recommend, I personally like a 65 or 70 series tire vs the 75 series. and keep it as small as possible. I use truck type tires, but run them again as small as fesible. This will make a big differnce. Also, helps to keep the tongue as high as possible. Good luck
