UTF vs 80W90
/ UTF vs 80W90 #22
I wasn't planing to use UTF indefinitely, just to run it for awhile doing light duty mowing to flush it out good.
If you want to just flush it out, fill the transmission with a 60% AW46 hydraulic oil and 40% diesel fuel mix, block the tractor wheels off the ground, and run through the gears for three to five minutes at a moderate engine speed. Drain for at least one hour and then refill with the specified oil.
/ UTF vs 80W90
Drained the trans/diff today and discovered it's had ATF in it for the last 7 years. Ever thing looks good and works well so I guess I'm going to run the UTF for some spraying I have to do(just transport, no pulling) then drain and go back with 80w90.
/ UTF vs 80W90 #24
My DF Chinese tractor has a common/combined gear transmission/ hydraulic so I use UTF with out issues. Are the gears that much different than other Chinese makes that are tranny only? I don't know.
My Shanghai 554 ( also a common sump) has been running jd 303 for years but the hydraulic pumps were whining to much in the winter months ,so switched to UTF around 2007 In all 23 years of use no problems-looking for many more.
ps. the front axle is also filled with UTF
Mercury Black Max 150HP Outboard Boat Motor. (A66738)
Mercury Black Max...
JOHN DEERR 850K LGP (A67714)
JOHN DEERR 850K...
2018 FREIGHTLINER M2 4X2 S/A 26FT NON CDL BOX TRUCK (A69167)
2018 FREIGHTLINER...
2014 FORD F150 CREW CAB PICKUP TRUCK (A66091)
2014 FORD F150...
2008 Sterling L7500 Series T/A Vactor 2115-J6 Combination Sewer Jetter Vacuum Truck (A66736)
2008 Sterling...
2011 CASE 580 SUPER N BACKHOE (A65056)
2011 CASE 580...
