Using tractor in water - Bad idea?
   / Using tractor in water - Bad idea? #21
I've done a fair bit of mechanical work over the years and cant say I've ever seen much (if any) damage caused by fresh water. Dirt and salt are the main concerns. They lead to worn oil seals, loss of grease, incursion of more grit, rust, and ultimately the breakdown of bearings etc. But fresh water alone is no great problem. It dries out.
That said, how clean is the water? Ive read that when a hot diff hits cold water it virtually sucks water into the diff through the seals as the air and oil inside the diff rapidly shrinks.
Thanks for the replies.
I didn't even think about the vent tubes. I'll have to check it out. Hopefully I haven't done any damage already ... the creek was relatively low. I don't cross that much in the Kobota but this thread has definitely taught me that I need to know my machine better. It's great to have you all as a resource.
I don't cross that much. We've crossed the creek on the Massey numerous times and in my F-150 occasionally. ATV is the only thing I've had damaged but it sees a lot more creek action.
A bridge is on the wish list - but then again there are a lot of things on my wish list. Can only get to them one at a time. :laughing:
   / Using tractor in water - Bad idea? #23
Just curious about why water is so damaging to a seal. I live in an area surrounded by 10,000 lakes and every weekend in the summer the landings are filled with boats going in and out of the water, all with the axles submerged and then sitting there in the water while the boat is launched or recovered. Often they have been driven hard for 200 miles from the Cities and the hot hubs get dunked in cold water. A boat trailer has pretty cheap, light bearings and seals compared to a tractor. Sure, there are Bearing Buddies but I can't recall anyone pulling out a grease gun and filling the hubs after leaving the water. How come I don't see the sides of the highways littered with boat trailers missing wheels? Sure, it happens once in awhile but usually seen on a rusty, 30 year old trailer that looks like it has never been serviced. Not saying everyone who says not to do it is wrong, just wondering why I don't see more casualties.
   / Using tractor in water - Bad idea? #24
first line of defense, as mentioned, is to relocate vents, with tubing...these are generally vented to the atmosphere, but I might consider capping them with balloons partly inflated ...my rationale would be to ensure some modest positive pressure ...not enough to blow a seal, but enough so no water would enter ...if you have greasable wheeel bearings, then consider grease used on boat trailers (marine grade, as mentioned) and look at "bearing buddies" or equivalent ...other than that, I would have little concern, although I might hose things down at the end of the day ...if you want to ford really high water, that's the time to look at relocating electronics, along with liberal use of dielectric grease, as well as ducting the fresh air intake and changing the exhaust to a vertical stack ...but, as far as I can tell from your pic, the water would never get high enough to compromise air intake and exhaust ...on my tractor, some of the "idiot-proofing" (like the HST safety switch that locks out the starter) would be vulnerable ...but, again, dielectric grease should do the trick ...all that said, I wouldn't worry about fording your steam at other than flood conditions and/or very fast moving water. I would, however, pay close attention to recommended greasing specs ...when you lube, observe the grease that is expelled and you'll quickly know whether you are tempting fate ...milky, yellowish...quite obvious.
   / Using tractor in water - Bad idea? #25
I don't know the OP's practice in this regard, but one thing to consider re. water is using a pressure washer.
Used to be, old tractors never got washed at all, other than by the rain. Today, some tractors get detailed way beyond what my car sees. Using a 3,000psi pressure washer anywhere near a seal can create way bigger problems than fording a creek once in a while, even without cleaners injected at the pressure washer.
Learned to think about this watching my buddy service his kid's MX race bikes - they are constantly being pressured washed to clear mud off the bike - he uses marine grade grease to help deal with the continual exposure to high pressure water.
Rgds, D.
   / Using tractor in water - Bad idea? #26
Be careful how deep you get. I had a family member with an L4400 that developed a horrible transmission leak at 125 hours. It turned out he had been digging gravel out of a stream and gotten water in the torque tube. This rusted the 4wd shaft to the seal when the tractor set for a week or so after. When he ran it next it dumped all the oil out of the transmission within a few minutes. This is an extreme case but it goes to show.
   / Using tractor in water - Bad idea? #27
looks like a prime place for some rough broken concrete ruble. Maybe call around and see if you can get some old sidewalk and curb debris, as it wont wash away like gravel. The water should still flow through the voids in the ruble or over it, and you end up with a shallow ford.
The water in the picture I took is about 2 to 3 times higher than when I cross it. I took it after a good rain. I'm going to buy a load of larger rock (around 9 in) and dump it at the crossing. All these stories of possible problems got me skerd.:eek:
I'll try to post some before and after pictures whenever I get it done.
Cheers!
   / Using tractor in water - Bad idea? #29
Pharm,
IMO - you are going about this in the correct manner. Large rock - as you indicated - will do these things for you---- provide a crossing point that allows the creek water to pass and keep the tractor out of deep water and be a point that is unlikely to wash out.
I was going to build a "road" across a really small valley on my property. I contacted Dept of Nat Resources and if I were to proceed it would have entailed a truck load of paperwork and a 6-8 month study on their part. It just so happened this small valley was a drainage swale between the two lakes on my property!!! I'm just going to wait a couple more years and then just do it.
More info coming soon! (A56859)
More info coming...
2014 DRAGON 130 BBL VACUUM TRAILER (A58214)
2014 DRAGON 130...
Tomahawk 42" Skid Steer Pallet Fork Attachment, Asset# 72 (A59076)
Tomahawk 42" Skid...
2014 Ford Fusion SE Sedan (A56859)
2014 Ford Fusion...
2014 REITNOUER MAXIMISER 48' FLATBED TRAILER (A58018)
2014 REITNOUER...
New/Unused CFG Industrial MH12R Mini Excavator (A57453)
New/Unused CFG...
