Using Tractor Hydraulics for Log Loader Trailer
   / Using Tractor Hydraulics for Log Loader Trailer #1
Dirigo54
Western Maine
John Deere 6220
I have a John Deere 4 wd 6220 with an closed hydraulic system. I also have a Hardy 1700 ST log loader trailer with a open hydraulic system. I am hoping to run the trailer hydraulics off the tractor system. Loader requires 8 gal/min and 2500 psi. Tractor runs 20+ gal/min and 2900 psi. Have not been able to get a good answer from local dealers. Might have to run a pto pump instead of using tractor hydraulics? Supposedly there is a kit that will create a free return line for an open system. Has anyone used this or know much about it? Hard to get good information...
Thanks!
   / Using Tractor Hydraulics for Log Loader Trailer #2
Might have better luck asking this in the Hydraulics forum where J J hangs out.
Thanks, I just posted it there as well.
   / Using Tractor Hydraulics for Log Loader Trailer #4
Have you checked if you can convert the valve to an closed center?
On many valves that are kits to do that.
Caterpillar 430D 4x4 Extendahoe Backhoe Loader (A51691)
Caterpillar 430D...
2020 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A50323)
2020 Chevrolet...
Alloway 1315 10"x61' Transport Auger (A50774)
Alloway 1315...
2014 DITCH WITCH RT45 RIDE ON TRENCHER (A51246)
2014 DITCH WITCH...
Ammco 6000 Drum/Disc Brake Lathe (A50322)
Ammco 6000...
TOW BEHIND FINISH MOWER (A50324)
TOW BEHIND FINISH...
