Using Railroad Track for bridge beams
/ Using Railroad Track for bridge beams #42
Is it practical to weld the rails togather in a truss style?
I’m sure it’s possible but the difficulty to cut railroad and it’s uneven shape that won’t weld good doesn’t make for a very practical project.
/ Using Railroad Track for bridge beams #43
We are replacing all the 90 lb rail (90lbs/foot) at our plant with 120 lb rail to serve today's larger cars. I now have access to sticks of the 90lb rail in various lengths (most 20+ ft) at no cost. I need to build a bridge to get my Kubota M6800 across a creek on my farm. A couple of times a week I stand there and look at this rail and wonder if I can use it as the beams for a bridge to span about 20 feet. The tractor has a loader and the tires are ballasted so I'm figuring about 9,000 lbs of weight.
Has anyone used rail as bridge beams?
Thanks in advance.
Go to a mobile home part and ask for a single unit that has either been condemned of occupant use or had a fire. You are after the trailer frame.
If the crossing is less than 45FT, then buy a 53FT sea shipping container to span it over. If it's even less, buy a 1/2 long container.
Semi truck trailer that was damaged due to an accident or a flipped one damaged due to high winds.
Not rails off the rail road, but a flt bed rail car would work.
/ Using Railroad Track for bridge beams #44
All the mobile home frames I've seen are very flimsy and flexible.. I suspect much of the mobile home's rigidity comes from the building structure, not the frame.
Thread about it.
Bruce
/ Using Railroad Track for bridge beams #45
The sea can or semi trailers are solid plans but mobile home frames barely support themselves.
/ Using Railroad Track for bridge beams #46
It is pretty much impossible to weld (you can but the weld won't hold) the top of the rail (where the train run on) it has been harden by quench so the only way to weld them together would be to preheat them and weld the two bottoms rails together.
/ Using Railroad Track for bridge beams #47
Now thats hard to believe🤣
I cant tell you how many house trailer frames I have seen on craigslist for sale to build a homemade trailer out of. They are just a house trailer with the structure removed......frame rails.....crossmembers......and axles. Listed as "HEAVY DUTY" trailer frame. Just needs decking🤣
/ Using Railroad Track for bridge beams #48
I wouldn't have problem with camper trailer, still wouldn't call it heavy duty tho ... I took apart an old house trailer on my property it was collapse and rotten so I basically just wanted to clean it up and get that thing out of there and I figured I could use the frame for a dock.... well, it's not even good enough for that... the cross members are two 1/8 flat bar one on top and one at the bottom with and 1/2 round steel undulated in a Z pattern in the middle.
/ Using Railroad Track for bridge beams #49
The house trailer frames that I have seen are made with
I beams and reinforced very sturdy. Made in the last 10 yrs
When I worked for Mr Choo Choo even the 6 inch ribbin
rails will bend, You could weld them together but them
you will have a tremendous amount of weight and I do
not believe that is will support any amount of weight.
Purchase some metal I beams let them know the span
and how much weight you want to run over them.
willy
/ Using Railroad Track for bridge beams #50
As I read the original post, it sounds like there is plenty of steel available. How many sticks were you planning to use for the bridge?
/ Using Railroad Track for bridge beams #51
Maybe put 20 of them across the creek, side by side, connected to its neighbors so a point load is shared by multiples... I wonder if putting them in an arched fashion (the ends butting into something solid, with the buttresses being slightly closer to each other than the rail is long, so that the bridge is somewhat arched) could increase the strength? or would that must make it more wobbly side-to-side...
If @LD1's calcs are right (check with an engineer!) in post 30 a single rail would deflect twice as much as desirable, but if you can tie them together somehow so that the load is shared, it sounds like it could be done.
I'm still in the "get an old flatbed rail car instead" camp, though - just because something can be done doesn't mean it's going to be easy or ideal.
/ Using Railroad Track for bridge beams #52
Whether you use for bridge or not, take those rails home. There will be a use at point in your life...
/ Using Railroad Track for bridge beams #53
My neighbor has a 1978 mobile home trailer that is constructed on 2 heavy duty 12-inch I-beams. These are massive and amazingly strong. It takes a 35Hp tractor just to move the the frame on wheels by itself. The mobile home part was destroyed by high winds decades ago. It's just a frame.
/ Using Railroad Track for bridge beams #54
Must be a rare good mobile home.
I have never seen one that I would rate ANY steel component as "heavy duty".
The I-beams are the lightest and thinnest I have ever seen.
/ Using Railroad Track for bridge beams #55
I would bet more on that being something that someone has built. Most mobile home frames are extremely flimsy. Camper frames are maybe a step better but they still rely on the box for stability and aren’t very sturdy.
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2019 Dodge Grand Caravan Van (A61569)
2019 Dodge Grand...
2005 John Deere 7320 (A60462)
2005 John Deere...
New/Unused Landhonor 24in Semi-Automatic Tire Changer (A61166)
New/Unused...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55851)
iDrive TDS-2010H...
2015 Freightliner M2 106 AWD Altec DM478BTR Insulated Digger Derrick Truck (A60460)
2015 Freightliner...
