Using propane instead of acetylene
   / Using propane instead of acetylene #11
most of the scrappers in my area are on oxy-propane.
   / Using propane instead of acetylene #12
I have been using propane since the 70s and am pretty familiar with it. I cut with it and a lot of times I use liquid oxygen. Liquid propane just doesn't make any sense to me.
   / Using propane instead of acetylene #13
The nice thing about propane is that you don't need another cylinder. 20lb tanks last FOREVER, so you can just steal your grill tank when needed. My only oxy/acetylene work was in class at the tech college, and they had a cascade bottle system that never ran out, so it isn't real fair to compare that to anything else, BUT...I found oxy propane at home sucks a ton of oxygen. Probably 3 or 4 125cu ft cylinders to one 20 lb propane tank. Never ran it all dry to be sure, but that seemed about right, from a rough estimate.
The reality is, like anything welding, it is more about time in the hood and experience/skill than anything. My torch work really sux, but i can cut stuff which is good to be able to do. You look at Shield Arc's stuff and don't for a minute think he is a first timer. He's been doing it for many years... That is one big reason why it looks so good. The other reason is pure talent. Some can do it easy, some can't.
   / Using propane instead of acetylene #14
I converted heating and burning to propane. I have all three bottles on my cart. Still have to use OA for welding steel which I do a lot of. The regular OA welding/brazing tips work fine on Propane. As far as I not there is no special tips of those for other fuel gases. Cutting tips are special to other fuel gasses as the preheating cone is different to provide the extra heat required. Never noticed the water problem mentioned above. Yes cutting is slower but cleaner. OA for heating will produce a hotter flame and smaller concentration than other fuel gases. The reason I use the term fuel gases as there are others that work as well as propane. The old MAPP gas is still around in those small cylinders, too expensive. Butane works for you guys down south, its not sold in the North as in the winter the pressures are too low. If you have it, natural gas is the cheapest way to go. A lot of big users go to utility piped in NG. Works as good as propane. watch the prices on propane they fluctuate and follow the same price curve as gasoline. Years ago a system was developed to use gasoline-OX for burning, it was slick, cheap then, and burned clean. No slag just a fine black powder residue. Fire departments were leery of it and were slow in allowing and usually disallowing it even though it was approved my NFPA. It died out real fast.
Ron
   / Using propane instead of acetylene #15
Seabee the first part of your post was a bit confusing to me. Just to anyone who wants to try propane they need to get a propane tip for their torch. It will be a two piece tip. You can take it apart to clean it and dress it up.
I hope none of you Seabees mind me using the logo. Dad was a Seabee in WW2. I always liked it. I was an airdale
   / Using propane instead of acetylene #16
Brazing tips will work for acetylene or propane but I think they're rated lower on propane. For cutting, generally a 2 piece tip is used for propane but there some that are one piece with a raised edge around the preheat holes. I think they might be for Purox but can't remember.
   / Using propane instead of acetylene #17
For you guys that have swapped over to propane.
As an estimate on your personal usage, does your oxy/propane set-up use about twice the amount of oxygen as you did with oxy/acet? Or is it more or less?
I'm trying to figure if the changeover will be worth it or not. I don't use the torch a lot. But when I have a project, I don't want to have to be frequently running to Airgas either.
   / Using propane instead of acetylene #18
I switched to propane a few years ago. I don't see a whole lot of difference between cutting with acetylene and propane. Like already stated it does take a little longer to preheat. But is does make some nice cuts.
Here is a good video on using propane.
Propane & Oxygen Torch Cutting Instructional Video - YouTube
Thanks for the video.
In the pic's you made, I noticed the cuts look smooth and hardly any slag. Is that typical with propane?
   / Using propane instead of acetylene #19
Vapor propane is what powers gas grills, heaters, and camping equipment in a normal residential bottle. Liquid propane normally powers forklifts and other engines but has to be preheated by the engines coolant heat to the converted to a vapor
Isn't Liquid Propane(LP) in the small gas grill bottles? It's been a long time since I had one filled, but if I'm not mistaken when they go to fill it they put the bottle on weight scales and weigh the liquid in them.
   / Using propane instead of acetylene #20
Propane is always stored as a liquid. It can be used as a gas or a liquid depending but you need a cylinder with a dip tube to use it as a liquid. Very similar to Co2. If you shake the little disposable propane cylinders, you'll hear the liquid inside.
2005 GEHL CTL70 TURBO SKID STEER (A51242)
2005 GEHL CTL70...
2018 John Deere 1445 72in Front Mower (A48082)
2018 John Deere...
2013 FORD F150 LARIAT CREW CAB TRUCK (A51243)
2013 FORD F150...
2008 JLG 450AJ SERIES II TELESCOPIC MANLIFT (A51242)
2008 JLG 450AJ...
2013 Jeep Patriot SUV (A50324)
2013 Jeep Patriot...
2013 Dodge Journey SXT SUV (A50324)
2013 Dodge Journey...
