Using my trailer, or abusing it?
/ Using my trailer, or abusing it?
Well, for comparison, here is a 7000# dual-axle flatbed equipment hauler.
Currahee Trailers - 500 series channel flatbed
Looks like it uses 3" channel steel (instead of angle), on 24" centers. Mine is the 3 x 2 x 3/16" on 30" centers. And, honestly, that is probably going to seal the deal for me, unless the manufacturer comes back with an unequivocal "yes"--but given that they build two trailers with the same capacity using dramatically different materials and techniques, I doubt that will be the case.
/ Using my trailer, or abusing it? #22
Between the gate and the cross members, it does seem like your landscape trailer is a bit on the light duty side compared to the landscaper I have. But in general, I would expect landscape trailers to be lighter duty than equipment haulers, based on what I have seen.
That said, on landscape trailers, the side rails carry some of the load, almost like a space frame or truss. So they almost always have lighter steel on the side frame and the C-channel of the A-frame when compared to a equipment hauler of the same load capacity. I think the crossmember size and spacing are the main difference in terms of beef.
/ Using my trailer, or abusing it? #23
Exactly, on a landscape trailer your top rail provides much of the strength to the trailer whereas on a equipment trailer there is no top rail, so the bottom rail has to be heavier.
Aaron Z
Interesting. Well, like I said, the manufacturer's response will probably be my final word. All this hemming and hawing, and I'm not sure why I didn't think to just ask them before.
/ Using my trailer, or abusing it? #25
Aaron Z
yep.. and I see lots of guys hack them off to use as a flat bed. and what they don't realize is they just made the thing less rigid, unfortunately..
/ Using my trailer, or abusing it? #26
I once beefed up a trailer for my brother. It was a common deck-over flatbed with foldable aluminium sideboards, with a pressed steel C channel as frame members, which corroded and finally cracked. I welded a new truss frame of 2"x2" tubes with LOTS of gussets, both vertical as well as diagonal (diagonal helps the most) and added a crossmember between each crossmember of the original trailer. I turned a common deck-over flatbed into a true multipurpose trailer, a deck-over tiltbed with a deck and frame suitable for hauling equipment like small tractors and mini-excavators, but also to take construction materials to the job. The only thing it cant do, is dump a load of dirt...
i also replaced some rusted siderails which turned out to be rotten after i took out the floor, and the towbar was reinforced with 2x3" square tubing to make it a more stable V towbar, instead of the single 3" pipe which was prone to sway.
In the end it would have been just as expensive, but could be done in 1/3 the time with much better paintwork, if i had just threw it away and build a new one on those axles.
I appreciate this perspective, as it more or less addresses exactly the concerns I have. That being said, I would love to be able to continue trailering my tractor with this trailer, but not if it's going to damage the trailer. Is there any way to assess the construction of the trailer to get a sense of whether it's "enough" or not? I don't know about trailer construction, but by way of analogy, I design wireless networks for a living, and if you told me you had an office building with one radio per 10,000 square feet, I would instantly know the design wasn't up to the task. Something like that. If I was to give more information about the construction of the trailer (thickness of steel, spacing of cross-members, and so forth) would you give me a (non-binding, all Internet disclaimers apply) opinion?
if this is your trailer: Currahee Trailers - 800 series deluxe double-axle
I'd suggest to trade it for an equipment hauler before the wire mesh ramp and the crossmembers are sagged.... dont know how the trailer business is in North America, but here it has to be cheap, and lightweight to maximise fuel economy... So no safety margin beyond the intended use of a landscape trailer... hot rolled angle profiles are cheap, but no good for carrying a tractor...
/ Using my trailer, or abusing it? #27
Well, shoot, as long as I'm poking around the manufacturer's web site, I may as well ask them. If they say it's okay, on the record, in today's litigious environment, that's got to be gospel.
Ask them in an email and get thier response. If you ever needed it it would hold up better than "they said ... over the phone".
/ Using my trailer, or abusing it? #28
euuhh.... If there is ever a chance you would need the statement to "hold up" if they said yes, the answer will definately be a NO, so they are safe...
This is my perspective too. I fully expect them to come back with a "no." If it was me, I would say, "Dear sir. If you want to transport heavy vehicles, we make a 7,000# car hauler trailer that is right up your alley, and we will be happy to refer you to your nearest dealer to discuss a purchase." But if, by some freak chance they do come back and say yes, then I am going to be as convinced as I possibly can be that it is fine, because if there is even the smallest chance that it's not okay, they are just going to say no.
/ Using my trailer, or abusing it? #30
BUT the website and im sure the trialer itself says 7000GVWR. This means you tractor will be fine on it, if not it would say something like 5000#GVWR.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Rooster Weathervane (A59231)
Rooster...
GENERAC MAGNUM PORTABLE LIGHT TOWER (A59823)
GENERAC MAGNUM...
2007 DRAGON 130BBL VAC TRAILER (A60736)
2007 DRAGON 130BBL...
John Deere XUV825E (A61307)
John Deere XUV825E...
CFG Industrial H12R (A60463)
CFG Industrial...
