Using loader scv for rear hitch attachments.
   / Using loader scv for rear hitch attachments. #1
Hawgheaven101
Mahindra MAX28XL
Would it be ok to remove my FEL and use the joist stick to operate rear attachments, I.e. Pull behind brush mower to raise and lower the unit with the hyd lift cylinder?
   / Using loader scv for rear hitch attachments. #2
Yes, you can run other equipment with the joy stick. Just use caution when running the hoses to the rear to prevent them from catching or rubbing on something.
Out of couriosity if I put the lever in float will it run a wood splitters two way motion?
   / Using loader scv for rear hitch attachments. #4
No, there is no flow of oil in the float position. But you can bungee the joystick to keep the flow going and use the valve that's on most 3PH splitters.
2019 Fontaine Traverse HT T/A 48ft. 41 Ton Hydraulic Dovetail Equipment Trailer (A52377)
2019 Fontaine...
2017 Mitsubishi Mirage G4 Sedan (A53424)
2017 Mitsubishi...
2016 HINO 268 26FT BOX TRUCK (A52141)
2016 HINO 268 26FT...
2017 Hino 268 20ft Flatbed Dump Truck (A52377)
2017 Hino 268 20ft...
2022 FORD F-150 XL EXT CAB TRUCK (A51406)
2022 FORD F-150 XL...
