Using an extra loader valve for rear remotes?
/ Using an extra loader valve for rear remotes? #1
npaden
Platinum Member
Lubbock, Texas
2011 LS U5030C
I have a line on an extra joystick loader valve with all the trimmings. I was thinking that I could use this for 2 rear remotes pretty easily. It is going to be a little bulky, but I was thinking I could figure out a way to get it mounted where it wouldn't be too much in the way.
Am I missing something here, would there be any big pros or cons to using a loader valve for rear remotes? I was thinking it would be nice for a top and tilt setup as you could run it with a single joystick.
Thanks, Nathan
/ Using an extra loader valve for rear remotes? #2
No problem at all, just make sure the flow rate (GPM) matches or exceeds your tractors specs.
/ Using an extra loader valve for rear remotes? #3
I have used one that way for several years. It works great.
2019 INTERNATIONAL LT625 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2019 INTERNATIONAL...
Landhonor Mini Skid Steer (A60352)
Landhonor Mini...
Brady 512 Feed Wagon (A66408)
Brady 512 Feed...
New/Unused 16 Gallon Landhonor Vacuum Cleaner (A65583)
New/Unused 16...
84in. Light Duty Fork Extensions (A65640)
84in. Light Duty...
Lonestar Panel (4) 24ft. Free Standing Panels (A65640)
Lonestar Panel (4)...
