two_bit_score
Super Star Member
- Joined
- Dec 22, 2008
- Messages
- 12,555
- Tractor
- John Deere 110 TLB, Diamond C 19LPX GN trailer
I already knew the hp ratings for various augers from reading sales listings, etc..
As for $200, notice I said I'd be into $200 for a weeks rental @ $100/week plus a double RT to fetch the tool. It won't be my first PHD experience, just never used larger than what I've owned for many years.
Over engineering: Hmm. I suppose the engineering wall loads can be ignored and I've done it before but they are there for a reason, not something I dreamed up. I could do as the pioneers did and set it on rock piles. I can bet you this, the thousands of pole barn builders across the USA do what the build site and buyer allows per codes or not. I live in a zero code county other than an electrical or plumbing inspection some spots. This is off grid and on a farm so zero inspections. If one ignores the engineered wall load specs and I use my 12" auger, the number of piers quadruples from 9 to 4x9 = 36 holes with 12 auger. The larger holes save not only concrete but much labor as fewer tubes to fill. The cleaner worksite an auger provides vs. a backhoe/excavator is attractive too.
As said already, This soil is deep timber at the base of the ridge on a bench. For about 8-12" it's black forest soil then clay interspersed with sedimentary rocks/sandstone that fell down off the cliff above when dinos roamed. Some are big enough to be a problem. I suspect most holes would go OK though. it's not a spot where you'd plant trees using a 24" auger as in a tree nursery by any stretch!
What some are saying is that your auger may not give you the best results if you have much clay/rock/hard soil because of the size you want to use. I understand the DIY aspect so have you considered renting a mini-ex with a powered auger and a 24' bit? You would probably be better off in the long run and your job may be done much quicer and cleaner with less risk.
Just a suggestion as you seem to know all about what you are doing.
TBS
