Used Disc; Worth?
/ Used Disc; Worth? #1
Phred
Arkansas
TN70D, 4wd, 16x16 trans
Guys,
Found an old beat up 3 point disc. Its about 7', although I did not measure it.
Very little paint left, but for these types of units I figure an old rusty model still has value.
At any rate I could easily sand blast and paint it.
How much would you buy or sell one of these for?
Thanks
Fred
/ Used Disc; Worth? #2
Fred, you buying or selling? If you're buying, check the spindle bearings and each blade. That's where you're refurb expenses will be. That's a pretty good sized disc for a compact. Is it adjustable for gang angle?
If you're selling, I'll give you $50 for it /w3tcompact/icons/wink.gif
/ Used Disc; Worth? #3
That would go for around $100 at an auction, or less.
/ Used Disc; Worth? #4
I'd pay a $100 + for that setup. I would figure on putting in new bearings, if I was going to use it a lot. I'd like to find one in that shape. It looks a bit big (try it on your tractor, and sell it if it doesn't work out), but one could shorten the sections with a bit of work. From the picture, the individual blades look to be in pretty good shape, and that's a plus. Looks like a good find.
/ Used Disc; Worth? #5
I imagine that the TN70D won't have any trouble pulling it.
Chris
/ Used Disc; Worth?
guys,
I should have said right up front that what I know about these things would not fill a thimble.
I was thinking about buying, but have no idea what the value of such an old unit is.
The blades look pretty good, rusty but its mostly surface rust. What should I look for in the bearings?
Also no idea who manufactured this unit. How hard would it be to find parts?
I plan to pull it with a 4wd TN70 which is not really a true compact. I can't imagine that this thing is more than ~2000 lbs which should be with in the tractors capabilties.
Thanks for the advice.
Fred
/ Used Disc; Worth? #7
Oh geez Fred with that TN70 you could pull a disc three times that size!!
/ Used Disc; Worth?
Doc,
I thought that might be the case but it never hurts to be conservative.
John,
The new dics I have looked at are pretty light duty. The thing I like about these older units is that they are very heavily built.
Fred
/ Used Disc; Worth? #10
<font color=blue>...The thing I like about these older units is that they are very heavily built...</font color=blue>
I agree...!
Best bet is to pick up an older unit at an auction {square steel tubing frame}... so it will outlast the tractor using it... /w3tcompact/icons/blush.gif
{I only posted the "new" discs strictly for reference... against your posted angle iron pic...}/w3tcompact/icons/wink.gif
/ Used Disc; Worth?
John,
Is the square frame that much better?
Appears to have more adjustment capability?
The units at my local dealer, that are heavy duty, cost more than I am willing to fork over. Tractor supply has cheap ones but these are very light duty.
Fred
/ Used Disc; Worth? #12
<font color=blue>...Is the square frame that much better?...</font color=blue>
The angle iron units are cheaper and weaker... /w3tcompact/icons/wink.gif
Any of the framed units, whether square or tubular steel are much more durable and stronger... these seem to last forever...
New/Unused Wolverine Quick Attach Quick Coupler (A65583)
New/Unused...
2022 EZ-GO ELITE...
2023 New Holland Powerstar 90 Tractor (A65579)
2023 New Holland...
2015 Peterbilt 337 Galbreath CH8000 Container Handler Truck (A64194)
2015 Peterbilt 337...
2020 Ram 1500 Pickup Truck (A64194)
2020 Ram 1500...
Bobcat 60� Rotary Cutter (A64047)
Bobcat 60�...
