URGENT help needed....
/ URGENT help needed.... #41
Take photos of the work {wink, wink}
/ URGENT help needed.... #42
Sounds like you are on the right track. About that epoxy stuff. My oil cooler sprung a leak and agco tried their usual price gouging wanting over 300 dollars for it. Tried to match it up at napa and oreilys. No luck although similar coolers were like 40 and 50 dollars. Parts house guy convinced to try cleaning it with brake cleaner and try patching it with this epoxy stuff he had. I was skeptical but gave it a try. Turned out to be one of the best 12 dollars i ever spent. That was 2 years ago and patch is still holding.
/ URGENT help needed.... #43
Sorry to hear about your first day break. I would not buy a used radiator. You got a real deal on a nice machine, for a great price. Now bite the bullet, buy the new one and don't worry why it cost less, maybe dealer wants to get his money out- who cares?
Don't try epoxy on plastic radiator header, it WON'T work. Plastic tank, aluminum core radiators are made of materials that will NOT stick with epoxy. You'd need a plastic welder and the right plastic to make a repair. I know; I owned and ran a foreign auto shop in previous life, and worked with industrial plastics doing solar engineering for the DOE in another earlier life.
Go new, forget shields, drive carefully. Enjoy new tractor. Post pics when able.
/ URGENT help needed.... #44
I would have to agree that in this application a new radiator may be the best way to go. I would think a used radiator would be hard to come by. Tractor is to new, don't think there would be any in the junk yards yet. He mentioned the epoxy thing and thought i would share my experience. It did adhere to the aluminum, but the guy at the parts house said if i didnt prep it right, didn't mix the epoxy and hardener right, and then let it set up, that it would not work. I will admit i was skeptical. It was not jb weld, it was something that he had and with my experience i believe i will throw rocks at jb weld.
/ URGENT help needed.... #45
So....
Do you have to start the tractor to remove the loader?
OP is good, but more food for thought:
1) Don't drag racers and multi-engine pulling "tractors" often run dry blocks? Massive horsepower and rpms for 300 feet or 1/4 mile plus. (2+ minutes total run time?)
2) What is standard operating temp on a tractor, compared to the temperature thermostat opens at? If knowing how long it takes engine to get to normal temp, doesn't this give you an idea on how long engine runs without even opening the thermostat (basically the same situation if you clamp the hose)?
Some of them have small radiators. And probably closer to 30 seconds or less run time. If you clamped off the lower hose on the broken radiator and filled it up that would ease concerns about the water pump bearings. I’d guess running like that you’ve probably got 10 minuets at low rpm in modest weather before it over heats.
/ URGENT help needed.... #46
I tried to patch a leaky radiator in my Silverado with epoxy and then a radiator patch kit. Both failed and I did a proper surface prep job the second time. I ended up replacing it with a new one for about $80.
Like I mentioned, I did order a new radiator. The epoxy comment was only related to the YouTube video, not something I'm going to try with a new tractor.
I'd be happy to post some pics, but this forum is different than most that I'm used to and I'm not seeing the buttons to insert images. Is it the Manage Attachments button? Also, subscriptions are not working for me. I have this thread set to Subscribe-Instant Email and I get nothing.
/ URGENT help needed.... #48
Join the crowd on figuring out how to run this forum. I'm not a high tech guy, when i need to do something cute and creative like post pics, i get my wife to do it. Hang in there and you'll probably be ahead of me in a couple hours. I just thought i would share my epoxy experience and of course it stirred up a hornets nest. I'm settled in my convictions and really don't worry to much about political correctness or whose apple cart gets upset or who's house of cards gets toppled.
/ URGENT help needed.... #49
About loading photos... depending on your computer, it could be different ways on how to do it.
This photo, I used the little icon at the top, or if you have the option, press the "Go Advanced" near the bottom.
If you have taptalk or a smartphone... I don't know and can not help...
In Advance mode, look below the "Submit Reply" button to "Manage Attachments" if you need farther help, just ask...
That row of buttons is what I'm used to seeing on other forums, but I'm not seeing it either on Quick Reply or Go Advanced. I'm using Chrome.
2016 Texas Trailers 26ft 5 Ton T/A Dovetail Flatbed Equipment Trailer (A59230)
2016 Texas...
DRILL CABINET SKID (A58214)
DRILL CABINET SKID...
iDrive TDS-2010H...
2014 Ford Escape SUV (A59231)
2014 Ford Escape...
2014 Ram 1500 4x4 Crew Cab Pickup Truck (A59230)
2014 Ram 1500 4x4...
2025 78in Dual Cylinder Hydraulic Brush Grapple Skid Steer Attachment (A59228)
2025 78in Dual...
