Upgrading from JD 870 to JD 3x20 series
   / Upgrading from JD 870 to JD 3x20 series
Also, I just checked ebay for your 870 but didn't see it listed (I'm not an ebay expert but looked under "John Deere 870").
   / Upgrading from JD 870 to JD 3x20 series #12
I think he means he sold it a while ago, that picture is just 1 he had up during it's sale.
   / Upgrading from JD 870 to JD 3x20 series #13
Sukee, yes I sold it awhile back and that was just one of the listing pictures. I know that itch well and you will probably have a powerful urge to satisfy it. Go luck with your new tractor if you decide to go that route.
Sincerely, Dirt
   / Upgrading from JD 870 to JD 3x20 series #14
I found the 3520 to be somewhat unstable on slopes initially but after putting the wheels in the wider setting, getting some wheel weights and always running with something on the back (ballast box or whatever), it seems fine or maybe I'm just used to it. The tires are loaded R-4's.
Not sure what makes the 3x20 less stable feeling - maybe it's the fact that it uses relatively small tires for its height?
   / Upgrading from JD 870 to JD 3x20 series #15
It is a few inches taller than the 4310 and the rear axle appears to be 2" slimmer. I went with some Turf Specials on all 4 wheels and that did the trick for me without any fluid in the tires. I also have another set of tires, R4's and they are loaded - rears..
2020 PETERBILT 337 BOX TRUCK (A51222)
2020 PETERBILT 337...
Swamp Buggy (A49346)
Hydraulic Hose Reel (A49461)
Hydraulic Hose...
2019 JOHN DEERE 331G SKID STEER (A51242)
2019 JOHN DEERE...
2012 MAXEY TRAILER MFG 100KW GENERATOR TRAILER (A50854)
2012 MAXEY TRAILER...
2016 Ford F-450 Crew Cab Knapheide Service Truck (A49461)
2016 Ford F-450...
