Upgrading from JD 870 to JD 3x20 series
   / Upgrading from JD 870 to JD 3x20 series
Also, I just checked ebay for your 870 but didn't see it listed (I'm not an ebay expert but looked under "John Deere 870").
   / Upgrading from JD 870 to JD 3x20 series #12
I think he means he sold it a while ago, that picture is just 1 he had up during it's sale.
   / Upgrading from JD 870 to JD 3x20 series #13
Sukee, yes I sold it awhile back and that was just one of the listing pictures. I know that itch well and you will probably have a powerful urge to satisfy it. Go luck with your new tractor if you decide to go that route.
Sincerely, Dirt
   / Upgrading from JD 870 to JD 3x20 series #14
I found the 3520 to be somewhat unstable on slopes initially but after putting the wheels in the wider setting, getting some wheel weights and always running with something on the back (ballast box or whatever), it seems fine or maybe I'm just used to it. The tires are loaded R-4's.
Not sure what makes the 3x20 less stable feeling - maybe it's the fact that it uses relatively small tires for its height?
   / Upgrading from JD 870 to JD 3x20 series #15
It is a few inches taller than the 4310 and the rear axle appears to be 2" slimmer. I went with some Turf Specials on all 4 wheels and that did the trick for me without any fluid in the tires. I also have another set of tires, R4's and they are loaded - rears..
2015 Ford Explorer AWD SUV (A48082)
2015 Ford Explorer...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
1270 (A50490)
1270 (A50490)
Unused 2025 CFG QK16R Mini Excavator (A49461)
Unused 2025 CFG...
2006 MACK GRANITE CV713 DUMP TRUCK (A51406)
2006 MACK GRANITE...
