Update on all 7520s
/ Update on all 7520s #101
Dave - These guys here seem quite intelligent and I believe I've read more than a few times that they have attempted to get some attention from Mahindra on this issue. Having called and written to Mahindra on other issues myself, I know how hard that can be. If you can do those ML275 lift speed tests you talked about with your new 7520 and 6520 machines, you would be doing a great service to those guys and would once and for all resolve the issue on whether or not those two hydraulic pumps/pump capacities (i.e., 6520 vs. 7520) are the same or, in fact, different. That alone would be a giant step toward solving the mystery. You and the other dealers here on TBN do all of us Mahindra owners a tremendous service. We cannot thank you enough. Where the factory falls down, you guys fill the gap. I'm not sure Mahindra would be such an attractive brand if you gentlemen were not around.
Dougster[/quote]
Amen to that!:)
/ Update on all 7520s #102
RedRiver said:
I just went out and tested a 7520 4WD on our lot. I let it run for about 10 min. ran the rpm's at 2100 and it lifted to full height in 6 seconds flat.
This just can't be correct, a tractor that specs out better than the specs?:rolleyes: :D Now I,m thinking that my tractor really is as good as I thought it was.:) Now I am going to have to test mine just to see for myself. Is it possible that these are actually better than advertised? Do we have super tractors here?:rolleyes:
We need more confirmation, come on Dave, it's lunch time, it can't rain all day.;)
/ Update on all 7520s #103
I did not have a stop watch handly, so I could see that I might be .2 seconds off.
/ Update on all 7520s #104
Hey y'all,
I just timed the 6520 4WD on my dealers lot. It would be mine if it had the skid steer option. I warmed it up for a minute, as it is 77 degrees out side, cranked it up to around 1650 rpm and timed the loader raise. I didn't rev it higher because the fuel guage was sitting on E. It took under 6 seconds to raise the loader to max height.:) Now I will be pissed if my 6520 doesn't do this. :mad: This is better than any spec I have seen in print or online. But it sure makes me wonder if someone is putting on pumps that look alike, but are different in GPM and this 6520 has a 17 GPM pump!
It is just as bad with the 6520 4Wd weight. The sales broucure says 7300 pounds. The Ops manual says 6515 pounds. A 785 pound difference. When someone (me) is trying to peg down towing weights, these conflicting figures throw everything out the window. Does anybody know how much the ML275 weighs?
hugs, Brandi
/ Update on all 7520s #105
OK, I about froze and someone owes me a Starbucks Grande Mocha...but here is what we have:
7520 4wd with ML275. 2500 rpm - 5.38 seconds, 1500 rpm - 8.29 seconds.
6520 4wd with ML275. 2500 rpm - 8.18 seconds, 1500 rpm - 12.43 seconds.
These are tractors that idled at 1500 rpm for 20 minutes before the test. Both are current machines. Both were significantly slower (but not timed) when cold. I'd say the 7520 time is impressive, as the 1500 rpm speed is real usable with all the torque this monster produces. As someone mentioned, at 1500 rpm the tractor is just loafing, but will pull a house of it's foundation, therefore most of us would use the loader at this rpm, +/- 300 rpm. The 6520 time beats specs a little also, but in my opinion is a little slow at the lower RPM. An experienced operator with a lot of loader work will be waiting on it a little an will have to bump up the throttle.
Also keep in mind that unless you are loading a truck, you often lift the loader from the ground to perhaps 3 feet, then carry it and dump it. It takes less than 2 seconds to lift it that far. If you need it faster...you are in too big of a hurry. :rolleyes:
/ Update on all 7520s #106
bindian said:
Hey y'all,
hugs, Brandi
Brandi, that 6520 must have the 7520 pump...you'll want to grab that one. On weights, it looks to me that they are identical tractors, except for the engine and tires, where they differ slightly. rback33 will have to give us a weight on the loader, but I'd say either 6520 4wd or 7520 4wd with loader will weigh between 8500 and 9000 lbs. Add weights and fluid and you can get to 5 tons. Nice round number, Mountain Ranch has his real heavy like that.
/ Update on all 7520s #107
Excellent... thank you Dave! :) I'll have to owe you the latte until my lottery win comes in! :D Finally we have side-by-side, current production, "new and clean" benchmark tests which tend to support the currently published specs on both the tractors and the ML275 loader including the fact that there is a clear difference in performance between the 7520 and the 6520 (although Brandi's post... together with Larry's rumor suggest this might be changing?).
Nothing more satisfying than an accurate side-by-side test. :) Of course, this doesn't help Larry and Billy to solve their lift speed problem... but it does show that it is not a design flaw or spec error. If not an assembly, maintenance or wear problem, that kinda leaves them with manufacturing flaws and/or faulty pumps.
Dougster
/ Update on all 7520s #108
Brian, blue paint slows things down considerably. Problem solved.
CuzPat, we have some good numbers now from several people. If your loader isn't close to that, it needs fixed, and your dealer should be happy to be involved.
/ Update on all 7520s #109
Good news! Thats what it should do, since 17GPM would do stop to stop in 5.2 sec. Mine takes between 8 & 9 sec to do a 22.5 extension on the cylinders, which is only 22.5/24 of the full travel. CuzPat, your dealer should clean those couplings in the suction line. This is a messy job and will be covered under the warranty. Im going to get mine to do it while it is at the shop for the engine warranty repair work.
Thanks for the timer p/n RedRiver! I think mine is malfunctioning as well.
larry
/ Update on all 7520s #110
Dave,
On the weight, I was just referring to the 6520 4WD. The weights in the sales brocure and the Ops manual are 785 pounds different.
CuzPat62,
Where can I purchase a Diamond plate aluminum canopy?
hugs, Brandi
/ Update on all 7520s #111
Dave, it's not just the blue paint, but the heavy duty digging bucket that I usually have on.:cool: I will time mine with my 84" std duty bucket this weekend when I get up to the ranch.
This is so great that this has finally been answered.:D Now all we need is to get the guys that have these hydraulic problems taken care of and I believe that everybody will be happy once there tractors operate as they should. These owners will be impressed, once their tractors operate properly. The 7520 is a very capable machine.:)
Good luck to all.
/ Update on all 7520s #112
bindian said:
CuzPat62, Where can I purchase a Diamond plate aluminum canopy?
hugs, Brandi
Brandi,
There is a man here in Alabama that makes them and he distributes them to tractor dealerships all over the Southeast. I will locate his name and number and post for you tomorrow. I got my canopy from my Mahindra dealer and it was one of this gentleman's canopies.
Will get you that info tomorrow as promised.
Billy
/ Update on all 7520s #113
Dave,
I have the Mahindra bale spear on my tractor right now. Do I need to put the 84" bucket back on before I do a test on my loader? I will try to test mine ASAP and post the results.
/ Update on all 7520s #114
DavesTractor said:
OK, I about froze and someone owes me a Starbucks Grande Mocha [ quote ]
Ok, I just bought & sent you your Starbucks, not sure how good it will be when it gets to you though.:eek:
Hope you enjoy it:)
/ Update on all 7520s #115
CuzPat62 said:
Dave,
CuzPat. Neither of those implements is heavy enuf to affect the lift rate to a degree you would notice. The hydraulic pump is positive displacement and therefore delivers a certain volume per revolution. Without a load on the arms there is very little loss to internal pump leakage - and even with a heavy load theres not much more. You dont need to change the implement.
larry
/ Update on all 7520s #116
My dealer is sending a Service Tech out to my place on Monday to put the new KSB sensor/timer and jumper wire on. That will be a good time to do the test. I will get it done on Monday while the Service Tech is here and then get the results posted. One of us can run the stopwatch on my cell phone and the other can operate the lift. That way there won't be any indescrepencies with getting it started and stopped on time while trying to operate the loader at the same time.
Billy
/ Update on all 7520s #117
Good to see everyone elses tractors are lifting to the same specs as the one on our lot, for a minute there you guys had me feeling like I forgot how to count. ;)
/ Update on all 7520s #118
larry
I agree with Spyder. A few hundred pounds either way won't make a tenth of a second difference.
The suction line fix would not seem like a reasonable fix for a loader that is 50% too slow, but I am told it will fix it. We had the West Coast Mahindra service school here at our place last Tuesday and Wednesday, and that was an item they went over. I've not tried it myself, so I will be interested to see the results posted.
By the way, your Mahindra dealer should be attending these schools if at all possible. There is a lot of good info, and they need to care enough to keep up on it. We missed a few dealers due to bad weather, guys getting sick, etc., but we had a good turnout overall.
/ Update on all 7520s #119
Dave, its because the bubble in a suction line expands a lot due to the vacuum, limiting the ability to pull fluid from the reservoir. - - The pump draws its correct volume but theres much less liquid in it. Then on the pressure side the bubble is compressed to near zero volume and contributes nothing to flow.
larry
/ Update on all 7520s #120
Timed my loader this weekend, now have in mind that I have the hydraulic self leveling option, which means that there is a lot of fluid going to the curl cylinders also. I timed at 2500 rpm's:eek: (scary with no load) and 1750 rpm which is a more common rpm range for me.
2500 rpm, ground to full height 7.5 seconds
1750 rpm, ground to full height 8.5 seconds
I would have thought that at 750 rpm slower, that the lift time would have been slower than it was. Maybe the self leveler does other stuff with the fluid, I don't know.:confused: All I know is that I am happy with the lift times that I have.:) I did each test 5 times, same result each time.
I was going to time the loader on my Case 580E so that we would have a commercial tractor to compare to, but my brother took off with the keys.:( Maybe at another time.
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
Landhonor Skid Steer Bale Spear, Dual Spear  (A62679)
Landhonor Skid...
2008 Ford F-250 Lariat 4X4 - 303,424 miles - 6.4L Powerstroke -Automatic (A63689)
2008 Ford F-250...
2012 ISUZU NPR CREWCAB 16FT BOX TRUCK (A59905)
2012 ISUZU NPR...
2022 Chevrolet Tahoe SUV (A61574)
2022 Chevrolet...
2022 EZ-GO ELITE...
