SPYDERLK
Super Star Member
- Joined
- Feb 28, 2006
- Messages
- 12,642
- Location
- VA
- Tractor
- JD2010, Kubota3450,2550, Mahindra 7520 w FEL w Skid Steer QC w/Tilt Tatch, & BH, BX1500
Brandi and Dougster. Yes there are a lot of discrepancies in the literature. Iv seen all those #s and I wish I knew which are right. i hadnt seen the 6.2 sec boom raise associated with the 6520 tho, but that wouldfit what the tech rep said about them putting 17GPM pump on both.
The Hi Idle rpm is limited at 2500 on mine. Even tho a 2750 redline you cant get there without changing a factory set adjustment. No reason to cuz it makes the power at low-mid 20s. Wed, Ill be going to the dealer where they are working on my engine. A Mahindra tech rep will be there. I will ask a lot of questions over and above the engine problem. The correct and specified performance of the tractor is very important to me - thats why I chose it. At 17GPM the loader should go from bottom to top stop in 5.2 sec. That would often be faster than you want, but you dont need to rev above 1800 or so to have surplus power for loader work - so theres plenty of the usable rpm range to slow it down. My loader has lots of omphh but no speed unless the engine is really buzzing. Ill be working on getting an explanation and remedy. Ill keep yous posted.
larry
larry
