Unnecessary MMM greasing
/ Unnecessary MMM greasing #1
oldballs
Elite Member
Kansas...USA
Kubota B2620 , Case 448 , Kubota B2650
Using my B2650 with MMM, or similar set ups, how often (hours) would you TBN'ers grease the MMM zerks and PTO shaft U-joints ? I'm OK with maintenance, but decided that I've been over doing it.
Cheers,
Mike
/ Unnecessary MMM greasing #3
Depends where you live and the weather.
Generally you grease if it's been sitting/hookup, if sitting in a normal climate once or twice a year. On hookup is just good practice and a reminder, otherwise on fluid change with everything else.
If you live somewhere hot and dusty you will want to do it more often and maybe use a higher temperature grease to keep out the dirt. Cooler and damp, maybe a silicone or graphite type, lots of different agri grease out there for different reasons.
Every 10 hours sounds like someone who is mowing roadways everyday in the heat?
/ Unnecessary MMM greasing #5
I mow about 3 acres with my 62" MMM deck.
About every 10 hours the bearings and wheels get a pump or 2.
About every 50 hours the u-joints get one pump.
So far...........I like the answers......maybe I have been over doing it. Every ten hours is a lot easier on my old knees and shoulder. Thanks gents. Just gotta make the MMM etc....last as long as I am lasting.
Cheers,
Mike
/ Unnecessary MMM greasing #7
10hrs or so, can't say "once a year" or any other timeframe, you've got to take a look once in a while to make sure it's not drying out or contaminated. I error on the side of caution over greasing most of the time, keeps me in the habit of slowing down to inspect equipment more.
/ Unnecessary MMM greasing #9
I grease the Ujoints for implements when I put them on. Where's the grease from a Ujoint going to go? They last the life of the vehicle generally if sealed up. If you do not overgrease them and blow things apart, the grease isn't going to go anywhere.
/ Unnecessary MMM greasing #11
Actually Ralph, it gets contaminated with dirt and metal particles from the joint itself.
And at that point it turns to more of a sand paper. Giving a U joint a squirt every 10hrs of mowing shouldn't hurt any thing. Some may say that grease attracts dirt and that's true but also where the seals in your U joint come into play.
Maybe you are talking about a rear mount mower....
The MMM are different in some respects.
/ Unnecessary MMM greasing #14
I have found that the wheels on the deck lose their grease quickest. Also the high speed bearings on the blade spindles. The u-joints and slip joint on the pto shaft seems to hold it's grease for a long time.
/ Unnecessary MMM greasing #15
No ramps for yours or no FEL? Unless you are one of the lucky ones who can have both mounted at the same time?
Quite a few brands now have drive-over decks and quick hitches for their mid mounts.
It is nice that it is now an option, not much room for clearance but an acceptable option, especially for landscape/maintenance usage. I think about making mid mounts every once in a while, but I am not sure that only 2 months a year justifies it until one of the rideons pack it in.
/ Unnecessary MMM greasing #17
I grease my ZD mower decks (and everything else) every 50h, which is what the manual recommends for the most part.
I do 3 pumps on the spindles, 1 or 2 for the universals, 6 for the king pins and wheels, and 2 for the deck wheels.
/ Unnecessary MMM greasing #18
I'm hoping this is the case. Greasing the u-joints on mine requires removing the deck or at least disconnecting the shaft from the tractor. I have found connecting this shaft to be a real PITA, it takes me forever to get it lined up and started while lying on my back/side and reaching under. I've run it 10 hours since I put the deck on and was planing on greasing the tractor this weekend.
/ Unnecessary MMM greasing #19
On my pull-type 7 ft Woods mower, I go 8-10 hours on the U joints and 20 or so on the spindles. On the four rolling rear wheels, I give them a quick hit of grease every time I mow my 2.5 acres. It only takes a moment for that.
Sure, the wheels are maybe overkill but it's just a metal shaft in a metal hole so the grease is gone quickly. On the plus side, in many decades of mowing with different mid and rear mowers, I have never replaced a stub wheel or spindle or anything other than a belt. My equipment feels and operates like new and I like that as well.
Just for the hellavit.......I looked in the OE manual for my model of MMM. Actually the manual is kinda generic and vague as to the maintenance schedule IMO....as to greasing frequency. I counted 13 zerks just on the mowing deck...plus...3 more for the PTO shaft/U-joints.
That's a lot of grunting for an old man....to be done only as necessary. Heck, my tractor, by itself, only has one zerk for the whole thing....the HST pedal.
I think I'll stay with 10 hours with special attention to the spindles and gauge wheels & brackets.
Cheers,
Mike
2023 KOMATSU D61PXI-24 CRAWLER DOZER (A65056)
2023 KOMATSU...
2018 PETERBILT 520 6X4 T/A GARBAGE TRUCK (A66091)
2018 PETERBILT 520...
GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A68842)
GENERAC MOBILE...
CULVERTS / PIPE STAND (A68842)
CULVERTS / PIPE...
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A61573)
2021 Mercedes-Benz...
2019 INTERNATIONAL MV607 REEFER TRUCK (A67714)
2019 INTERNATIONAL...
