Loader Unlevel bucket
   / Unlevel bucket #81
I was told by the one of the people at our local RK that the loaders/BH's and 3-Point implements are made by King Kutter- I have no way to validate this.
I have an RK 24 and my end loader and backhoe ID plate says manufacturer: Tong Yang Moolsan Co. Located in Seoul Korea.
   / Unlevel bucket #82
Mine too. They're made by TYM.
King Kutter only makes the 3point implements that Rural King sells. Which they always have. The only difference is once they started selling the tractors, they had ing Kutter start painting the implements red and putting RK stickers on them for their stores.
   / Unlevel bucket #83
A common denominator in this whole thing is the assembly location. I'd bet there is an issue with how the loader frames are aligned and tightened when installing them on the tractors. These were all assembled in either the Ohio or Florida service/assembly points after importing. It doesn't take much movement (misalignment) at a mounting point to reflect an inch or two difference at the bucket. It could be as simple as the order the bolts are tightened, if they are all tightened gradually, or how the frame is supported while assembling, to get a loader frame mounted square.
Makes a person wonder if a bit of strategic shimming when remounting the loader brackets might fix the out of level issue. Might be worth a try.
   / Unlevel bucket
Porkchop, I noticed that your tractor was no longer sitting out in the bull per area so I assume you got it back????.......Don
   / Unlevel bucket #85
I’m guessing the RK Tractor Guy (Doug) isn’t around anymore????? And I haven’t heard anything from RK about the loader issue.
   / Unlevel bucket
Yea, Doug left RK about 3 weeks ago. Not sure why.
   / Unlevel bucket #89
RK has worried me from the beginning. I hope for the best and prepare for the worst.
   / Unlevel bucket #90
Me too. I invested way too much money in their equipment.
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A56436)
2023 Unverferth...
DEUTZ MARATHON 60KW GENERATOR (A58216)
DEUTZ MARATHON...
ROLLING METAL RANK & CONTENTS (A58374)
ROLLING METAL RANK...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
DRAGON 500 BBL FRAC TANK (A58214)
DRAGON 500 BBL...
2020 CATERPILLAR 323 EXCAVATOR (A52709)
2020 CATERPILLAR...
