Loader Unlevel bucket
/ Unlevel bucket #121
Robfnk, you've given no info as to where you are located so others can help you look. It took some time but I located a trailer dealer/renter here in Lakeland, FL that rents the equipment trailers for a little under $100 per day. There might be something in your area too if you find the right combination to Google but we need a location......Don
I am located half way between Orlando & Titusville
/ Unlevel bucket #122
If you are near Christmas or Bithlo - you're right, there is not much out there - even the St John's River is more like a ditch where it crosses Hwy 50
Have you checked with
/ Unlevel bucket
Yesterday I was out using my FEL and thinking about the unlevel bucket issue and how wide spread it seems to be. I have pretty well ignored the issue for the last year or so but today I decided to go back in and see if there has been any new ideas or solutions. If I remember correctly it was Gunny0628 that they loosened the FEL mounting bolts and re-torqued them with the FEL level to corrected his. Then a few months back he posted that it had become unlevel again. After that robfnk discovered his was unlevel. Robfnk, did you ever get yours corrected? Next question is has anyone tried loosening and re-torquing their FEL themselves and if so did that fix it? I was thinking of parking my tractor on my concrete driveway, correcting any tire pressure issue then lowering the bucket leading edge to the concrete so I know for a fact that it's sitting level. Then loosening all FEL mounting bolts so any difference in the FEL frame mounting with even out. Then re-torque them in a pattern of a bolt on the left and then the corresponding bolt on the right side until all are done. It doesn't appear that it would be that hard of a job. Unlike robfnk, my bucket stays uneven when dragging in float mode. Now that I have finally fully retired at 73 I have a lot more time to spend on projects. My bucket only has about 1.25 inch difference between left and right side so it's able to be lived with but now it's starting to eat at me again. Hope everybody stays safe......Don
/ Unlevel bucket #124
I would thread lock on the bolts, so they cannot loosen up.
/ Unlevel bucket
Btown, I don't think it's an issue of the bolts loosening up but an assembly issue. It appears that all the owners that have reported the issue are in the south east where the tractors were assembled in Williston, FL. I downloaded the loader manual today and it gives instructions for attaching the loader to the tractor as if you purchased it after the fact. It appears that there's only 6 or 8 bolts per side that actually attach the FEL to the frame of the tractor. Once the rain clears out so I don't have to lay on a cold wet ground I'm going to try and loosening and re-tightening them with the bucket in a known level position. Once I finish I'll post the results for those interested......Don
/ Unlevel bucket #126
Don, you might note how big those clearance holes are for the bolts too. If designers made them sloppy to aid assembly, all you have is clamping friction.
And maybe scribe a line or two after realignment that spans both mating surfaces in case it distorts again. The shift in those witness marks might be insightful.
/ Unlevel bucket
Good suggestion jmc. I'll do that. This has been going on so long that I can't remember for sure but it seems like all the folks that has the issue it was the same side of the bucket that was lower. If that's the case and the only owners reporting this have units assembled in Williston, FL, that would lead you to think it's a assembly procedure or maybe an issue with an alignment jig if they use one wouldn't you?
/ Unlevel bucket #128
Is Williston an assembly plant or a dealer? I always assumed the dealer mounted the loader, for compact shipping and not needing to provide "with loader and without" tractor inventories.
/ Unlevel bucket #129
I'm in central Ohio, so I assume my RK37S was assembled at Waverly, Oh. Bucket is unlevel. Haven't gotten around to leveling yet, as being unlevel has not caused any problems in the work I do with it, but appreciate all the posts about fixes.
/ Unlevel bucket
jmc, Williston is one of the two assembly sites in the US. From what I was told when I ordered mine the dealer receives it completely assembled with the options your ordered. When I did the order I was given a choce of tire type and what attachment(s)such as FEL I wanted installed. I was given a delivery date of two days later and the dealer told me that if would be ready for me to take a couple hours after arrival once all the serial numbers on the paperwork was verified.
Tree Farmer Dave, as far as I know you are the very first person outside the south east that I know has spoken up about this. Be sure to check your time pressure all around because that plays a role in the position of the bucket. Make sure when you check the tire pressuire in the rear tires that the valve stem is at the 12:00 position since the rears are filled with beet juice. I have been very happy with mine other than the bucket issue and the paint fades very quickly if exposed to the sun. Mine sits outside 24/7 so it's faded to a dull orange. FEL is still nice and bright. But what the heck, it's a tractor.
/ Unlevel bucket #131
This sounds fascinating.... just the sort of project that we look forward to doing: Making it better with little to no chance of making things worse. Plus the chance to learn something in the bargain.
I also like the idea of witness marks both before and after. That will tell you what change actually took place. Can't wait to hear how it all turns out. Take some photos if you haven't yet. I have a feeling that this is common to lots of loaders.
Engineering wise, bolted joints should hold under clamping pressure alone. Bolt holes are allowed to be a specified amount oversized. So if the clamping pressure is not holding it firm, the answer is to go with larger or higher strength bolts so that you can use higher clamping pressure i.e. more torque on the fastener bolts.
Best of luck,
rScotty
/ Unlevel bucket #132
Yup....it is "just a tractor", and while it sits outside in hot Florida, every single Korean hose and rubber part is rapidly deteriorating, with your instrument console/gauges fading as well.
/ Unlevel bucket #133
Best of luck,
rScotty
That's fair about "friction should be enough" but I'd feel a lot better with an abutment close enough to limit any slip should it happen. I also wonder about the two layers of thick paint sandwiched in there not to shear under load and allow movement. Another reason for a close abutment.
Either way, if RK used coarse threads with nuts, fine threaded bolts, with their shallower threads, could probably provide more clamping force.
/ Unlevel bucket #134
Your better off having some, they are notoriously famous for loosening up on tractors and by the time you figured out they are loose they have either sheared off or rounded out the holes. I know it’s an assembly issue because I haven’t heard anyone with a TYM complaining about the issue. They are pretty much identical tractors. Different paint and decals.
/ Unlevel bucket #135
Why not use at least blue Threadlocker, or maybe even red Threadlocker?
/ Unlevel bucket #136
If it was an assembly issue specific to the Williston FL TAC, then I believe they have licked the problem. I've got a month on my RK37, and 240+ tons of fill dirt later you can still barely slip a dime under either edge of the loader. I really like the witness mark idea. Think I'll do that now in case mine slips later. Thanks for the tip!
/ Unlevel bucket
Hey cowpen, hopefully you have one without the issue. It's great to hear that someone has a straight one. I haven't moved anywhere close to that weight of material. I didn't even notice it until I was going to level down some dirt mounds left by some pocket gophers. As I drug the bucket backwards over the mound I noticed that one side was around an inch or so higher. I drove onto my concrete driveway and lowered the bucket to just above the concrete. Then looking at the front of the tractor it was obvious that one side was 1 to 1.5 inches higher. I posted on this site asking for suggestions and tire pressures not being correct was the most viable. I then corrected the pressures all the way around to specs but that didn't help. Then the other owners started chiming in. It's not something that keeps me from doing anything but just grates at me that it shouldn't be that way. Have a great day......Don
/ Unlevel bucket #138
An earlier thread made me check out my FEL leveling.
Surprise, I was off a reasonable bit.
Turned out to be a FEL frame bolt had worn out the hole enough to be the cause.
I pried things back to level and cheated, (LOL welded it fixed).
Correct cure would be to ream out the holes and install an oversized bolt however that day I was in a lazy mood.
Moral is to check torques on most fittings from time to time, (especially rim attachment*).
* I scrapped one rim due to very oval holes!
/ Unlevel bucket #139
So whats the torque spec on the FEL bracket bolts? My FEL is like everyone elses, its off by over 1.5 inches from one side to the other. I first noticed something wasnt right, when I removed the FEL, this spring for mowing. The drivers side pin wouldnt come out easily, the passenger side slid right out.
/ Unlevel bucket #140
Hey guys. Haven’t been on here in awhile mostly because I don’t use the tractor much in the cooler months. My bucket is still not level despite them taking it and torquing the bolts and whatever else they said they tried to fix it. Not sure what the real problem is, I could never get a straight answer. Someone said it was put on wrong (one person doing the job versus two people). I’ve given up at this point.
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A61567)
Pallet of...
(8) Massey Ferguson Tractor Suitcase Weights (A65640)
(8) Massey...
SKID STEER VIBRATORY ROLLER (A62613)
SKID STEER...
2011 JOHN DEERE 710J BACKHOE (A65053)
2011 JOHN DEERE...
Kivel Skid Steer Forks (A65640)
Kivel Skid Steer...
2021 TAKEUCHI TL6R SKID STEER (A65053)
2021 TAKEUCHI TL6R...
