Unhappy new member
/ Unhappy new member #1
fja50t
Lagrange,IN
JD la105
I came here looking for information to keep my JD LA105 lawn tractor running.
My tractor has given be continuous problems including a worn mower deck, a bad carburetor that needed to be replaced, and constant mysteries with the safety switches. I have snow blade with chains and weights but it can't touch a good Indiana snow. Basically I am zero percent satisfied with a tractor that I bought because of the name.
Thank you, I hope to learn alot from y'all. (used to live in Texas)
/ Unhappy new member #4
Your lawn mower is probably not heavy or powerful enough for snow removal, unless you have a blower on the front. Pushing snow...more then a few inches, isn't really a mowing machine's forte.
/ Unhappy new member #5
I'm sorry to hear you're unhappy. Next time you should do more research. Buying a machine because of the name painted on it obviously doesn't constitute due diligence.
/ Unhappy new member #6
Welcome to TBN.
"As a lawn tractor, the John Deere LA105 is ideal for maintaining smaller lawns. It has a cutting width of 42 in, which is not as wide as most (the average lawn tractor has a cutting width of 50 in)."
Sounds like you have lawn tractor instead of garden tractor for your needs...Check out TBN reviews.
/ Unhappy new member #7
Your tractor is a lower end JD that was priced compareable to the MTDs of the world. I just bought a D110 that is the newer version of your type. I know what I got and know it's limitations, but I only have a small lot and it will work fine for what I need. I agree with Roy when he says it really isn't big enough to remove snow but you would have to had paid at least double you did to get the heavier JD.
/ Unhappy new member #8
Welcome to the forum.......sorry about your concerns. Others have already said it but.....you have a lawn mower.....not a tractor......you might be expecting too much from that machine. Any options of trading it in for a bigger unit??? Good luck.....
/ Unhappy new member #9
:welcome: fellow Hoosier. The LA105 is an entry level mower not designed for Indiana snow removal. How much area do you need to clear and what is the surface? Would a walk behind snow blower be enough?
/ Unhappy new member #10
what's this, Gary ??? you've left Bakerville for Tilbury ? and traded your red for green ?
Pete
/ Unhappy new member #11
You should also be disappointed in your dealer. He should've asked what you were going to be using it for and sized it to your needs. It would be in his best interest, and he'd have a happy repeat customer.
You could search Craigslist for a used front mount snowblower for it.
/ Unhappy new member #12
Dealer might be Lowes or any other store that hires people with no tractor knowledge.
/ Unhappy new member #13
As others have said, in one way or another, you did not buy the wrong name, you bought the wrong model for what you want to do.
Did you buy it from a JD dealer or a big box store?
/ Unhappy new member #15
Sorry but you purchased something that was not designed to do the jobs you intended to do with it when you made the purchase.
A friend or co-worker probably lead you astray by telling you that they owned a similar unit as what you purchased and it would do everything you would ever do.
As Koua has pointed out, the transmission will be marginal if used solely for grass mowing and a ticking time bomb if used for other chores.
/ Unhappy new member #16
Unfortunately, the LA series was designed for price, meant to be sold at Lowes, Home Depot, etc alongside other cheap mowers. Really, it's no better or worse than any of the other mowers in that price range, but I suspect many customer are fooled into thinking it's better because it's a Deere. You would have needed to step up to a Deere LT or X model (depending on age of your LA) to get into a higher quality machine. You'd also have needed to pay a lot more.
What year is the LA, and how many hours on it?
I bought a Deere LT-150 back in 2002, and it's still going strong 12 years later. I suspect it will outlast me. Back then, Deere offered a cheap "Sabre" model line (equivalent to your LA) and the LT series. There was a huge difference in build quality and the LTs were noticeably beefier in every regard than the Sabres. Price wise, the LTs were more than double, but you definitely got what you paid for.
/ Unhappy new member #17
My BIL had a La series, What a piece of crap that was. Always broke and can't be relied on but he got it cheaper than my unheard of to him Simplicity.
/ Unhappy new member #19
Should have come on this website wayyyyyyyy before you bought a LA series mower.
/ Unhappy new member #20
Welcome from wv. Back when I worked part time at lowes we sold tons of those la 105 mowers because of paint and easy financing. Not a high quality product"........
