Uneven cut - gt2550
/ Uneven cut - gt2550 #1
Ron Conlon
Hi I have a 2005 GT2550 with a "cyclone cut" deck. The problem that I have is that the middle of the cutting path is much higher than the sides. In other words, after cutting a straight path, there is a "hump" of higher grass left in the middle. I have checked that the blades are set at the same height.
I mow with the mulching plug in. On drier, shorter grass it is less noticeable, but on taller, lusher grass it is pretty unsightly. I already spend 2 hours mowing the 2 acres and don't want to have to double-mow to get rid of the stripes. Any suggestions?
/ Uneven cut - gt2550 #2
Just a few ideas on what could be causing it..
Are any of the blades bent? Is the underside of the mower clean? I mean VERY little grass stuck to the bottom of the deck. Are you running the engine at full RPM? Are any spindle bearing worn? Did this happen last season?
/ Uneven cut - gt2550 #3
Did you level the deck front to back?
It started 2 years ago, but then I had to have a landscaper mow last year due to family matters. After getting evrything ready to go over the last few weekends I mowed yesterday and said "oh yeah, I forgait about that."
I don't think I have a bent blade.
I see what you are saying about the front-to-back leveling. Because the center blade is set forward, if the deck is tilted up then the center would cut higher, correct? I'll check that out.
/ Uneven cut - gt2550 #5
Ron - don't forget to check/adj both front and rear tires air pressures per your manual before measuring/tweaking your deck....
might also do a quick visual to make sure that center blade is not either badly dulled/worn or even mounted upside down...
1998 MAC 39' Frameless Dump Trailer (A66285)
1998 MAC 39'...
7' Disc (A62613)
7' Disc (A62613)
Kubota L295-DT Loader Tractor (A66285)
Kubota L295-DT...
Case 1845C Skidsteer Loader (A66285)
Case 1845C...
2026 NORSTAR IRONBULL T/A 25FT GOOSENECK TRAILER (A59914)
2026 NORSTAR...
2008 Kawasaki ZX1000 Motorcycle, VIN # JKAZXCE1X8A013733 (A65563)
2008 Kawasaki...
