Mowing unable to move trailing arm on haybine
   / unable to move trailing arm on haybine #1
jd2130
Upper Peninsula, Michigan
John Deere 2130, kioti ck25
Hi,
I have a New Holland 492 Haybine that I bought used and I can't move the trailing arm into any other positions. There are three holes for positions where I can mount the arm for mowing and one hole to position it for transport. I can pull out the pin that goes in these holes, but when I try moving the arm (with the tractor) with the pin pulled out, the whole implement moves instead of the arm. I tried oiling up the area where the arm attaches, but this didn't help.
What am I doing wrong?
Thanks in advance!
   / unable to move trailing arm on haybine #2
You have to block the passengers tire to keep it from rolling, then it will swing out.
Just like my spare JD MoCo. I use a chunk of 6x6 for a block.
Thank you. I'll try this tomorrow if things dry up a bit. We've been getting a lot of rain here today.
   / unable to move trailing arm on haybine #6
On my 489 I usually had to pop the clutch a little in reverse or forward to get it to swing. Good coating of wheel bearing grease helps too,
Not a trailing arm anyway, it's the pivot arm.
Thank you guys for the tips. I chocked the passenger wheel and got the pivot arm to move, so I was able to get it across the culvert. I cut hay for a while and then one of the hydraulic lines sprang a really big leak, so I'm working on fixing that instead.
Caterpillar 6-cylinder Turbo Diesel Engine with Transmission (A55851)
Caterpillar...
2018 Chevrolet Camaro 1LT Coupe (A55853)
2018 Chevrolet...
2011 Ford Crown Victoria Sedan (A55853)
2011 Ford Crown...
30pc 3ft. x 8ft. Red Polycarbonate panels (A53424)
30pc 3ft. x 8ft...
2012 Chevrolet Silverado 2500HD Enclosed Service Truck (A53422)
2012 Chevrolet...
Case Wheels for Combine/Firestone Tires w/ extra rings NO RESERVE (A55315)
Case Wheels for...
