Mowing unable to move trailing arm on haybine
   / unable to move trailing arm on haybine #1
jd2130
Upper Peninsula, Michigan
John Deere 2130, kioti ck25
Hi,
I have a New Holland 492 Haybine that I bought used and I can't move the trailing arm into any other positions. There are three holes for positions where I can mount the arm for mowing and one hole to position it for transport. I can pull out the pin that goes in these holes, but when I try moving the arm (with the tractor) with the pin pulled out, the whole implement moves instead of the arm. I tried oiling up the area where the arm attaches, but this didn't help.
What am I doing wrong?
Thanks in advance!
   / unable to move trailing arm on haybine #2
You have to block the passengers tire to keep it from rolling, then it will swing out.
Just like my spare JD MoCo. I use a chunk of 6x6 for a block.
Thank you. I'll try this tomorrow if things dry up a bit. We've been getting a lot of rain here today.
   / unable to move trailing arm on haybine #6
On my 489 I usually had to pop the clutch a little in reverse or forward to get it to swing. Good coating of wheel bearing grease helps too,
Not a trailing arm anyway, it's the pivot arm.
Thank you guys for the tips. I chocked the passenger wheel and got the pivot arm to move, so I was able to get it across the culvert. I cut hay for a while and then one of the hydraulic lines sprang a really big leak, so I'm working on fixing that instead.
2013 Dodge Charger Sedan (A55853)
2013 Dodge Charger...
(4) CAMARO 5 LUG WHEELS & 245/50R16 97H TIRES (A54757)
(4) CAMARO 5 LUG...
Grey Metal Roof Panels (A55758)
Grey Metal Roof...
1997 CATERPILLAR 322BL EXCAVATOR (A52707)
1997 CATERPILLAR...
2016 Ford F-550 Palfinger PSC3216 4,000LB 2 Ton Crane Service Truck (A55852)
2016 Ford F-550...
2014 Ford F-150 Ext Cab 4X4 Pickup Truck (A55852)
2014 Ford F-150...
