Mowing unable to move trailing arm on haybine
   / unable to move trailing arm on haybine #1
jd2130
Upper Peninsula, Michigan
John Deere 2130, kioti ck25
Hi,
I have a New Holland 492 Haybine that I bought used and I can't move the trailing arm into any other positions. There are three holes for positions where I can mount the arm for mowing and one hole to position it for transport. I can pull out the pin that goes in these holes, but when I try moving the arm (with the tractor) with the pin pulled out, the whole implement moves instead of the arm. I tried oiling up the area where the arm attaches, but this didn't help.
What am I doing wrong?
Thanks in advance!
   / unable to move trailing arm on haybine #2
You have to block the passengers tire to keep it from rolling, then it will swing out.
Just like my spare JD MoCo. I use a chunk of 6x6 for a block.
Thank you. I'll try this tomorrow if things dry up a bit. We've been getting a lot of rain here today.
   / unable to move trailing arm on haybine #6
On my 489 I usually had to pop the clutch a little in reverse or forward to get it to swing. Good coating of wheel bearing grease helps too,
Not a trailing arm anyway, it's the pivot arm.
Thank you guys for the tips. I chocked the passenger wheel and got the pivot arm to move, so I was able to get it across the culvert. I cut hay for a while and then one of the hydraulic lines sprang a really big leak, so I'm working on fixing that instead.
Portable Restroom (A54865)
Portable Restroom...
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A52707)
2007 CATERPILLAR...
2014 Ford Taurus AWD Sedan (A54815)
2014 Ford Taurus...
(2) GAS HEATERS (A54757)
(2) GAS HEATERS...
Ford Super Duty FX4 Pickup Truck Bed (A51691)
Ford Super Duty...
Cushman Cart (A55853)
