Ultimate Shredder Idea......
/ Ultimate Shredder Idea...... #3
I would think one could flame or plasma cut the basic shape of the cutters and then weld on a carbide tooth or metal lathe bit making a two row unit about 6 inches wide, and slow gear it, most look like there hydraulic motors as they reverse when jammed,
Yes... I have thought about the "reverse when jammed" thing..... Definitely a job for a slip clutch.....
I guess it would be like any other pto chipper, chipper/shredder, if it jammed you would have to unhook the pto shaft and turn it back....
/ Ultimate Shredder Idea...... #5
depending on your tractor once disengaged, one could use some like a combine header reverse,
some of the first add on ones were just a flex plate/ fly wheel, and a starter motor. for the reverser,
/ Ultimate Shredder Idea...... #6
Has anyone put together this style of shredder that is PTO powered ???
Think it could be about 2' long, with maybe 8" diameter chippers.
And run on 20 or less PTO hp ???
Facts, ideas, facts, thoughts ???
Oh Snap.... Almost forgot the link
Waste Wood Shredding
I just dont get why people would want to burn that much fuel to generate fuel... This isnt woodchips, its mulch... In Eastern Europe i found a type of chipper which is much more energy efficient and creates material that burns just as good:
https://www.youtube.com/watch?v=iwO94lx_uh4
Just check youtube for "rebak" and you'll find plenty of home made contraptions that have a large capacity with a minimal power (fuel consumption) requirement :)
John Deere 4044M (A60462)
John Deere 4044M...
2018 Trail King Lowboy (A63689)
2018 Trail King...
2018 John Deere 5125R Tractor (A64047)
2018 John Deere...
Bobcat T590 (A60462)
1987 FORD F-350 CUSTOM SERVICE TRUCK (A64280)
1987 FORD F-350...
1988 Kenworth W900 Day Cab (A62613)
1988 Kenworth W900...
