Ultimate Shredder Idea......
   / Ultimate Shredder Idea...... #3
I would think one could flame or plasma cut the basic shape of the cutters and then weld on a carbide tooth or metal lathe bit making a two row unit about 6 inches wide, and slow gear it, most look like there hydraulic motors as they reverse when jammed,
Yes... I have thought about the "reverse when jammed" thing..... Definitely a job for a slip clutch.....
I guess it would be like any other pto chipper, chipper/shredder, if it jammed you would have to unhook the pto shaft and turn it back....
   / Ultimate Shredder Idea...... #5
depending on your tractor once disengaged, one could use some like a combine header reverse,
some of the first add on ones were just a flex plate/ fly wheel, and a starter motor. for the reverser,
   / Ultimate Shredder Idea...... #6
Has anyone put together this style of shredder that is PTO powered ???
Think it could be about 2' long, with maybe 8" diameter chippers.
And run on 20 or less PTO hp ???
Facts, ideas, facts, thoughts ???
Oh Snap.... Almost forgot the link
Waste Wood Shredding
I just dont get why people would want to burn that much fuel to generate fuel... This isnt woodchips, its mulch... In Eastern Europe i found a type of chipper which is much more energy efficient and creates material that burns just as good:
https://www.youtube.com/watch?v=iwO94lx_uh4
Just check youtube for "rebak" and you'll find plenty of home made contraptions that have a large capacity with a minimal power (fuel consumption) requirement :)
2011 Ford F-550 Bucket Truck - Power Stroke Diesel, Altec AT40G Boom, 45 ft Working Height (A56438)
2011 Ford F-550...
iDrive TDS-2010H...
SKID STEER ATTACHMENT GRAPPLE GRUBBER (A58214)
SKID STEER...
2019 KOMATSU D61PXI-24 CRAWLER DOZER (A60429)
2019 KOMATSU...
2017 Ford F-550 (A55973)
2017 Ford F-550...
2022 KAUFMAN 2 CAR TILT GOOSENECK TRAILER (A59905)
2022 KAUFMAN 2 CAR...
