Ballast Ultimate Ballast box
   / Ultimate Ballast box #11
Most important is it got the job done!
   / Ultimate Ballast box #12
jmarotz posted the 3ph spec's for the BX23 which are surprisingly alittle higher than the BX24.
BX23= lbs (kg) @lift point 1211(550), 24" behind 680(310)
I say surprisingly because the BX24 has 1 more hp and approx 0.8 more GPM than the BX23.
Could be that Kubota went more conservative since the 3PH links lift point was raised alittle higher than the BX23, giving it more lift height.
Kubota is known to be on the conservative side when listing specs.
   / Ultimate Ballast box #13
Somebody will figure out the weight,most rock type's weigh around 13lb per square foot per inch of thickness give or take depending on kind of rock.But this figure will ge you close.Some body start sizing this baby up.
   / Ultimate Ballast box #14
jmarotz - now that's what I like to see!
jb
   / Ultimate Ballast box #15
RayCo said:
Excellent pictures. :D I'm also quite interested in that grapple. American Solutions? I actually had a few questions, but decided to stop being lazy and searched. In case anyone else is interested, here's the link.
American Solutions LLC
Thanks for the link ray. Now I've just added another thing to the list of attachments to get. :)
Caterpillar Loader Quick Coupler (A56436)
Caterpillar Loader...
DEUTZ MARATHON...
TANK MANIFOLD (A58214)
Parker 6255 Gravity Wagon (A59814)
Parker 6255...
SCREENER (A58214)
SCREENER (A58214)
2024 Quality Steel Deck Over Tilt Trailer (A59814)
2024 Quality Steel...
