U1 Replacement Battery
/ U1 Replacement Battery #1
Dwellonroof
Batavia, Ohio
John Deere 3046r
I have a Scag Turf Tiger diesel that I bought used about 7 years ago and its battery finally died but I can’t seem to find a replacement. It’s a Remy battery with the round top post which apparently isn’t available anymore. Any ideas? It’s a tight fit already so it doesn’t appear that a car battery would fit.
/ U1 Replacement Battery #2
Take the old battery to Auto Zone. They should be able to measure and find a suitable replacement.
/ U1 Replacement Battery #3
It’s hard to tell by looking but it doesn’t appear to be a unique size. I’d think an auto parts store could find a match.
/ U1 Replacement Battery #7
Here's a link for a U1 battery:
None of those appear to be round post batteries. :rolleyes:
My Bad Boy uses a U1 battery but it has the bolt lug posts. There must be an indicator for the round post style. It's not U1R as the "R" designates the positive post position as being on the right side. I found a U1 battery with round posts but it looks like a special use battery. And it's over $250!!! o_O
/ U1 Replacement Battery #11
That looks like a group 51, about the same as a U1 only slightly longer by an inch or so.
/ U1 Replacement Battery #13
Do a search for automotive battery size chart or dimension chart. Then measure your battery to see what size it is.
/ U1 Replacement Battery #14
The BCI chart is my go-to resource when dealing with oddball applications, or when the battery type is not known.
/ U1 Replacement Battery #16
My Deere battery finally quit a month ago so I took it to our local Walmart. They had a battery same physical size but 500CCA instead of 550CCA. I installed it and it's been working fine. $79.
/ U1 Replacement Battery #17
change the cable ends
New/Unused Quick Attach Pallet Double Hay Spear (A65583)
New/Unused Quick...
2012 Peterbilt 367 Sleeper Truck, VIN # 1XPTD40X5CD149943 (A65563)
2012 Peterbilt 367...
Sakai SW354 (A64126)
2017 Cadillac Federal 70 IN Limo - 30,529 Miles w Premium Coachwork by Federal (A63689)
2017 Cadillac...
John Deere 6400 (A64126)
John Deere 6400...
UNUSED 2026 INDUSTRIAS AMERICA HYD TITL TRAILER (A60430)
UNUSED 2026...
