U-digger vs V-digger comments wanted
/ U-digger vs V-digger comments wanted #1
dapper
S.W. Ohio
NH TN-65, Ford/NH 3430, Ford/NH 3930, Kubota zd21
I have been looking at this attachment to do some much needed ditch cleanup and rebuild. The tool looks like it may be handy for a number of uses around the place including moving landscape items around for DW. It seems that there are 2 distinct versions of the tool. One having a rounded rear blade and the other being pointed on the rear of the blade. The difference being that when back dragging you would have a round bottom ditch, or a V bottom ditch. This may make a difference if I were to lay drainage pipe in the ditch.
I am having trouble choosing one over the other, and would appreciate your thoughts. Perhaps some of you may have used one or the other, and could comment on how it worked for you.
/ U-digger vs V-digger comments wanted #2
I have the Bobcat version, which you show as the first one (called "U" shaped). The only difference I see between the two shapes is that the second one has a point on the front and the back, where the Bobcat only has a point on the front. In use, I don't think you'll find that the point on either side will form the shape of the bottom of your ditch. When you ditch with this implement, the bottom is almost horizontal. You're basically slipping through the dirt, cutting the shape, but not removing the spoils. The spoils end up laying in the ditch and you have to come back with a FEL and dig them out. The advantage I see in the second version is that the pointed edge should cut faster and cleaner than the Bobcat version.
I like the implement a lot. When I bought it, I had both a Bobcat and my tractor. I have since sold my Bobcat. The Digger works fine on the tractor, but it worked even better with the Bobcat.
/ U-digger vs V-digger comments wanted #3
What type digger would you use if you wanted the soil moved out of the ditch in
the same pass with the tractor?
/ U-digger vs V-digger comments wanted #4
One a lot more expensive. ;)
I have seen a PTO driven ditcher/trencher. Looks sort of like the business end of a twist drill or a reamer. It spins and cuts and throws the dirt out of the ditch. 16 inches wide and up to 20 deep. Used they're priced in the 2 - 3K range. Don't know what they would cost new. 16 seems a little narrow, to me, too -- or maybe that is "sour grapes".
Thanks Jeff, this is just what I needed to know. :) In use it will be more level than tilted down then? I was thinking that it would be more useful by dragging backwards and this would make the ditch v-shaped. No? This would also clean out, or at least cause the spoils to be dragged out of the ditch? Doesn't work this way? I intend to clean up and soften the sides of the ditch with a box blade set at an angle to finish off the ditch to a level that I can bushhog through ditch. Do you think this would work? Also how is the blade for moving small shrubs, and trees? Have you ever tried it for that?
Thanks.
/ U-digger vs V-digger comments wanted #6
Dapper,
Where are you getting information on these diggers. I am interested in
looking at one too.
Hbob
/ U-digger vs V-digger comments wanted #7
No, if you tilt it back, the spoils just pile up in the frame, and you have to stop and dump them, but since it has no back, they don't dump where you want them to. You can slip cut your whole ditch in a couple minutes, then drag the spoils out and spread them with your FEL or box blade. You're right on track on coming back and smoothing out the ditch with the box blade. That is what I have done -- and what I have a bunch more to do in the coming weeks.
..... Also how is the blade for moving small shrubs, and trees? Have you ever tried it for that?
Thanks.
That is what is was originally designed for. It was designed for nurseries to root prune and move their trees. I have done a bunch of that. I am thinning out the brush in my woods, and for the 1-1/2 inch saplings, I can usually scoop them out in one pass. Then I hang the root ball over the hole, bounce the loader a couple times to shake as much dirt as possible back in the hole, and lay the tree in the burn pile. I have successfully moved a couple of redbuds from the woods to our yard, too.
Overall, it is a great tool. If I didn't have a backhoe, I would use it twice as much as I already do.
/ U-digger vs V-digger comments wanted #9
So is the u digger and v digger pictured in the first message Bobcat products or others. I am interested in a 3 pt attachement.
Thanks,'
HBob
/ U-digger vs V-digger comments wanted #10
The first one ("U" digger) is a Bobcat product. Not sure about the other one. They're both designed for skid steer mount, which many FEL's have. It wouldn't work on a 3 point. It needs more movement and angle adjustment than a 3 point has.
jeffinsgf, Great info, thanks.
That is different than what I had envisioned. But still sounds like what I need. Poor man's backhoe. :D Some of the manufactures advertise there scoop as a tree spade, although most of these tree spades are closed at rear. I was originally looking at the bobcat digger because of the round scoop at the rear, but if as you say, it really doesn't make that much difference, then I will probably go with the virnig u-blade because I would really like my local dealer to have some more of my money. :rolleyes: Actually the cost seems to be a wash as they are all about $1k by the time they get to my place. These diggers come in different sizes from 16" being the smallest to 36" the largest. I have been considering the 24" or 30". What would you say as to size? Larger or smaller make much difference? Really appreciate your opinion. Thanks.
Harley,
Jeff is correct in that the first one is a Bobcat "digger". Just follow Jeff's link. The second is a Virnig "u-blade"
A third possibility is Midsota Manufacturing, who call theirs a tree spade. There are others that are similar, but these things are hard to find, unless you know what the manufacture is calling them. From what I have seen, i don't think they would do well on 3pt hitch, as not enough tilt to use for digging. My original thought for this project was to use a 3pt "pond scoop". I think this would work fine for moving dirt, but same problem as my fel bucket, to wide for actually digging very deep, and not for a ditch to lay black plastic pipe in.
All thoughts are appreciated especially now before I pop for the thing. Thanks.
Virnig:
… Virnig Manufacturing …
Midsota:
Skidloader attachments, skid steer attachments, buckets, forks, bale spears, grapples, blades, skidsteer loader attachments
Pondscoop:
A & B EAGLE LINE EQUIPMENT The Shield of Quality
Joel,
Thanks, I have seen this in previous post's but don't think it would work as well as the open back design. I think this would be much hander on a skid steer than a FEL, as the steer is much more maneuverable. It would work well for digging stumps, rocks, etc. but I think the open back would work better for digging a ditch, or swale. Quite a few threads of people who have used this for successfully removing stumps. JMHO Thanks for input.
/ U-digger vs V-digger comments wanted #14
Hi, I built one of these for a bobcat, I added a flat plate at a angle of 30 degrees to the ground and 45 degrees to horizontal, think of another V taking off at a angle to the ground and direction of travel, when dragged backwards it deflects the spoils out of the trench and deposits in a pile to the side, it will dig a trench 20 inches deep by 18 wide "U" shaped bottom, when it warms up and the snow melts I will take a few pictures. It will also remove a 4 foot pine tree with root ball, only issue is you have to stab in the opposite side to loosen the soil around.
Laurence
laurencen,
Would love to see pics. My thought was that dragging backwards would clean out ditch, but jeffinsgf says that it isn't too good for cleaning out that way. maybe I can add your modification?:D Thanks for input.:)
New Holland 256 Hay Rake (A65579)
New Holland 256...
Heavy Duty Steel Baskets (A65579)
Heavy Duty Steel...
New/Unused Wolverine Quick Attach Coupler (A65583)
New/Unused...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A64194)
2019 Freightliner...
20ft Shipping Container (A65579)
20ft Shipping...
2016 CATERPILLAR CP44B PADFOOT ROLLER (A65053)
2016 CATERPILLAR...
