U bolts for ROPS
/ U bolts for ROPS #1
DDT
Platinum Member
Clay Center, Kansas
Kubota M6040/cab, BX25D, RTVX900
I want to strap my lights on the rops with 3" x 3" U Bolts. auto parts can only get them in 1/2" stud, I was thinking 1/4" or 5/16" would be heafty enough for a light. Any thoughts
/ U bolts for ROPS #2
John Deere parts has "black" U-bolts to match the ROPS... about ~ $2.... maybe 5/16" ?
/ U bolts for ROPS #3
Check your local Ace Hardware. I found the ones I needed there.
Hoss
/ U bolts for ROPS #4
DDT, I've used large stainless steel worm gear clamps that are available in plumbing supplys. As you tighten them down with a littte tapping they conform to any shape and give a clean installation.
/ U bolts for ROPS
Thanks for the help. I called my JD dealer and he did not know of any that size. Sounds like I can find some eles where.
/ U bolts for ROPS #6
DDT, If you just want 1/4" u-bolts, they are easy to custom make. I have done it several times. Just take 1/4" threaded rod and bend it in a vise to the size you need. Then cut some 3/4" or 1" wide flat stock to the right length and drill a couple of holes to make the clamp. You can make them any size or shape you need. For installations where I do not want them to scratch or to absorb vibration, I cover the threaded rod with black rubber fuel line hose. That makes it look better too.
Andy
New/Unused Landhonor Hydraulic Quick Attach Pallet Forks (A65583)
New/Unused...
2024 ANKONA 54" HANG-ON WHEEL LOADER FORKS (A62129)
2024 ANKONA 54"...
New/Unused Wolverine 72in Tiller (A65583)
New/Unused...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
HEAVYEQUIPMENT TIRES (A65643)
HEAVYEQUIPMENT...
2014 Grand Caravan (A62679)
2014 Grand Caravan...
