TZ22DA power loss
/ TZ22DA power loss #1
saxtonhill
Kubota L4600
I just bought a used tz22da with a 60" deck for mowing. My property is very hilly and steep. I mowed for one day and all was fine. Today I mowed and it lost some power whenever I turned uphill. Could this be a fuel filter issue?
/ TZ22DA power loss #2
Might be water in the bottom of the tank. Some fuel pickup tubes are not at the lowest point for this reason. Also make sure the oil is up to where it should be. You could be losing oil pressure going uphill.
/ TZ22DA power loss
I'll check that out thanks.
/ TZ22DA power loss
By oil pressure, do you mean hydraulic oil?
/ TZ22DA power loss #5
Most of the TZ series tractors had an inline fuel filter behind the left rear tire. Has that been changed lately? Most owners didn't know it was there until fuel starvation problems came up. As I recall the best way to access it is by removing the tire.
/ TZ22DA power loss #6
By lost some power do you mean the rpm dropped? Was your throttle still opened all the way? I had a problem on my TZ18 where while mowing, the throttle lever would back off. I had to adjust the cable and cable routing to stop it from doing this.
If that is not it, change both fuel filters, and check your air filter.
INTERNATIONAL 8100 SPREADER TRUCK (A63291)
INTERNATIONAL 8100...
2025 32in. Tilting Bucket Mini Excavator Attachment (A61572)
2025 32in. Tilting...
2006 Utility 53Ft T/A Reefer Trailer (A64194)
2006 Utility 53Ft...
2023 Freightliner Cascadia 116 S/A Day Cab Truck Tractor (A61573)
2023 Freightliner...
JOHN DEERE 7930 TRACTOR (A64280)
JOHN DEERE 7930...
250 Gallon Diesel Fuel Tank w/ Pump (A64047)
250 Gallon Diesel...
