tyre wear
/ tyre wear #1
redman135
nz
Case 105c
I live in a "keep left" country and accelerated tyre wear on the outside 1/2 of the left front tyre is common ie bald outside and approx 25/30mm of tread on the inside. Tractors observed are contractors units.
To those readers in keep "right countries". Do your tractors on high road use suffer from accelerated wear on the outside 1/2 of the right front tyre?
/ tyre wear #2
Yes, I just traded in a John Deere with an almost bald RF outside. Cars/trucks suffer from the same problem but not as noticeable if the tyres are rotated. Caused by the road crown ( slight slope engineered into roads to allow water to run off)
/ tyre wear
I had been told 2 theories.
1) road camber as you said.
2) axle is cambered for keep right market as keep left market is to small to be economic.
Unfortunatly rotating tractor tyres is difficult with fixed rims as you need to demount them and swap rims. Also under NZ law it is illegal to run directional tyres backwards.
2019 PETERBILT 579 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2019 PETERBILT 579...
2014 KUBOTA SVL75-2 SKID STEER (A64279)
2014 KUBOTA...
2011 Ford E-350 Passenger Van (A61573)
2011 Ford E-350...
2026 DEVELON DX27Z-7 EXCAVATOR (A64279)
2026 DEVELON...
2019 Nissan Sentra Sedan (A61574)
2019 Nissan Sentra...
2020 Peterbilt 567 Quint Dump (A62613)
2020 Peterbilt 567...
