TYM - T474HC My next work partner.
   / TYM - T474HC My next work partner. #1
Gasifier
Platinum Member
St. Lawrence River Valley, N.Y.
2013 Kubota L5460HSTC
Decided I wanted to get back into a HST transmission Tractor. Went with a new TYM T474 HC…..
Had the dealer load the rear tires, add a plug-in block heater, and the 3rd function kit down the loader. Should make for a comfortable, year round work horse.
Who else has one of these or the 494/574?
Put it to work mowing and taking care of some light duty loader work already. Had a bit over two hours on it when it arrived. Now has 7.1 hours on it.
   / TYM - T474HC My next work partner. #3
Nice piece of equipment, congratulations!
   / TYM - T474HC My next work partner. #4
I have the 574H. No cab because I live on a pine plantation. 75+ hours on it. No problems at all with the tractor. I've managed a few self-inflicted problems with my flail, though.
Just got done doing a quick mowing job along our paths. Rain is starting and we'll be in it for the next 4 days or so...just beat it.
   / TYM - T474HC My next work partner. #5
Very nice new helper; there are a lot of T474's in my part of Maine so there must be something to them.
@TractorTYMe you have a T474 don't you?
   / TYM - T474HC My next work partner. #7
I do, had it for 5 years now, working really well. 600h with no regen nor problems to speak of. Here it's doing its main purpose, pulling winter duties.
   / TYM - T474HC My next work partner. #8
I don't think the tier IV TYM diesels ever regen. Pretty incredible when every other manufacturer does it between 35-50 hours.
   / TYM - T474HC My next work partner. #9
If you work them like diesel engines are supposed to do, and do not idle for extensive periods and lumping along at low rpms. They seem to do passive regen just fine. Like when I do mowing with my 6' rotary mower for hours at 2400 rpms it just never need to do a requested regen.
I just leave it up around 2200-2400 rpm
   / TYM - T474HC My next work partner. #11
My neighbor has had his Branson emissions can replaced twice under warranty.
   / TYM - T474HC My next work partner. #13
Wow, that is rare.
I guess there are many people not on tractor forums or the internet.
I’m not sure the same 5 people saying the same thing over and over again on TBN makes something not rare?
   / TYM - T474HC My next work partner. #14
Well, when I also consider the # of emissions failures that I do see posted across forums for brands like LS, yeah, it's rare. Not all LS owners are on forums either I suppose 😂
Up over 11 hours on the T474 now. Some light duty loader work. But. Mostly mowing work with the Land Pride RCF2072. We actually had some time over the last few weeks with no rain! Or very little. So I was able to go through the trails even in the low spots. Still wet and muddy, but not as bad. I have to dig up some fill from nearby these low spots and get them filled in. Or get some cheap fill delivered and then move it all the way back to the back of the property to fill them in. A little at a time. It will be there when I get to it.
I forgot to ask you this question. What type and brand of chains did you go with for your T474?
Used the T474HC to move a pile of clay/dirt to some low spots today. Then cut the weeds down in the sacrifice pasture now that the horses are enjoying some other pastures. Running very well. The cab, AC, and radio were much appreciated. Bugs are on the glass and mirrors trying to get to me. The smaller size frame makes it easier to get around trees and into tighter spots.
2024 CATERPILLAR 259D3 SKID STEER (A60429)
2024 CATERPILLAR...
2010 Ford Fusion Sedan (A59231)
2010 Ford Fusion...
208315 (A58376)
208315 (A58376)
Bigfoot Plastic Baler (A57148)
Bigfoot Plastic...
2018 International WorkStar 7500 Aquatech B-15 Combination Sewer Jetter Vacuum Truck (A59230)
2018 International...
2006 CATERPILLAR 420E BACKHOE (A59823)
2006 CATERPILLAR...
