Backhoe TYM 273 backhoe
/ TYM 273 backhoe #1
N.W. Logger
Can anyone tell me how hard it is to install the backhoe yourself. (Frame mounting)?
/ TYM 273 backhoe #3
Are talking about removing it to use other attachments? If so, it's a 10 minute job. I've had mine off a couple times and it's a piece of cake once you learn how to position the bucket when unhooking it. If you get that right, you can back right into it, set the pins and hydro lines and your off. I'm not sure about starting from scratch, the subframe looks easy to install tho. One trick I will tell you, have a magnetic level handy. Place it on the vertical sheetmetal below the joysticks. That way you know how far to tighten the toplink to get the platform exactly level. If it's off one way or the other, it puts undo stress on the subframe and that's not good.
My Tractor
/ TYM 273 backhoe
Thanks for the suggestions. It doesn't look tough to do this frame installetion myself.
2009 KENWORTH T800 (A67714)
2009 KENWORTH T800...
BOAT MOTOR (A66738)
BOAT MOTOR (A66738)
2014 MAGNUM TRAILER (A68842)
2014 MAGNUM...
500 BBL FRAC TANK (A67714)
500 BBL FRAC TANK...
213063 (A64276)
213063 (A64276)
PORTA POTTY (A67714)
