TX1300 injector nozzle
/ TX1300 injector nozzle #1
watt4
tx1300
Hi i have a tx1300 with ke70 engine. Which injector (nozzle) is corect and what is the preasure to be set.
/ TX1300 injector nozzle #2
nozzle p#>> Denso> 093400-0010
Opening Pressure>> 1700-1850 PSI
Bottom nut on inj. must be torqued to 50-55 FTlbs.
/ TX1300 injector nozzle #3
are these the same for the TX2160 K3B engine? or do you have the part numbers of the nozzle and other stats.
Thanks
Chris
/ TX1300 injector nozzle #4
I have the Denso program on my home computer & it matches THE PUMP TO THE INJECTORS..
The EASIEST WAY for me to answer your question is to have the injection pump #..
Just like watt did..
IF your pump # is THE SAME.. the previous info is also..
IF NOT, just post your pump #..
/ TX1300 injector nozzle #5
Oh okay, unfortunatly my pumps are not in as good a condition so the lettering is not quite as clear, I have a spare engine to salvage bits from so here are some picture of both pumps, I will be interested to see if they are interchangable to the injectors, as both engines are K3B but the engine numbers a quite far apart.
Untitled by chrismac2012, on Flickr
thanks for your help, if you cant make out any of the numbers I can have a closer look for you.
thanks Chris
/ TX1300 injector nozzle #6
YOUR noz. # is 093400-0010
Opening pressure is>> 1700-1850 psi
Hi in my country denso is not avaliable. They sad that the foloving are the same:
- monark 39305014 (curently instaled)
- bosch 0434250014
- bosch 9430037212
- bosch 9432610012
I have ordered bosch 0434250014 but i noticed that are made in India and they do not work bether than the old ones.
I have set the pressure 125 bars (1800psi) it those not spray it looks more like when you open tap water.
Is the nozzle incorect or is problem that are made in india and not originale german quality?
/ TX1300 injector nozzle #10
The Bosch 014 noz are a direct cross to the Denso 0010 noz..
"SOME" noz from India, DO NEED to be "reworked" before they will atomize correctly..
Its not uncommon..
Unfortunately, you probably paid more for the Bosch noz than the Denso actually cost.. list price on the Denso noz are $14.00 US/each.
What do you mean "reworked". What to do, how, where.
Bosch noz cost from 35 to 50 euros, monark cost 25 euros. I pay 35 probably should pay 50.
/ TX1300 injector nozzle #12
When I put in new nozzles, the inj assembly is put on a "pop tester" & checked for opening pressure, correct atomization & leakage.
When the atomization isn't correct, the tip is removed & the pintle{center piece} is removed & "lapped in" to the body using 38-1200 lapping compound,
its cleaned & reassembled & the whole process is tried again..
/ TX1300 injector nozzle #13
25 euros = about $29.00 US LIST PRICE on the nozzles are $14.00 US.. THAT MEANS your paying DOUBLE what they sell for, for AFTERMARKET parts.!!!
Thanks for the information. I will try first on old noz to se what will hapen.
I have lapped the nozzles. One old noz works better the other is the same. New nozzles one much better the other like old on that is better. But non of the nozzles pops. When i slowly increase preasure oll nozzles drip, but when i pump faster one of new and one old spray olmost OK.
/ TX1300 injector nozzle #16
They're actually "throttling pintle" nozzles..
they aren't made to POP.. as long as the hold pressure at 200 psi BELOW opening pressure, no drips, its good.
Now the spray pattern is a diff story.. its checked at a full stroke & should be a nice conformed cone shape..
2021 HYUNDAI HX220L EXCAVATOR (A60429)
2021 HYUNDAI...
Schulte XH1500 15ft. Batwing Rotary Brush Cutter Tractor Attachment (A61572)
Schulte XH1500...
2017 FREIGHTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A59911)
2017 FREIGHTLINER...
213083 (A64276)
213083 (A64276)
Unverferth 432 (A64119)
Unverferth 432...
John Deere 4955 (A64119)
John Deere 4955...
