TX 2160F, with front loader and backhoe, long term project
   / TX 2160F, with front loader and backhoe, long term project
Well the 3 point linkage issue has now been resolved and my understanding of the hydraulics is a little better now too, I can now in the future get my head around how the spool valve is piped in,
Pipework to suit the manifold I had to get the 3 point linkage working only,
Untitled by chrismac2012, on Flickr
3 Point linkage set bought and fitted, some issues when fitting but got it all together, the upper swivel brackets did not fit so I ended up using the existing,
Next purchase is going to be a rotovator, give the little machine something to work with.
Been a little while since I have done much but I took the sump off and used the origional gasket and some rtv silicon and that seems to have cured the small leak I had, it was a good chance to check the bearings for my own peice of mind when I was in there,
I have started making a rear box
I have another wee project to keep me busy a godiva fire pump with a coventry climax engine.
Chris
   / TX 2160F, with front loader and backhoe, long term project #54
Hi Darryl, thanks for the comments its been a steep learning curve, yes thats one I used to own, I have a bit of a collection now,
Chris
   / TX 2160F, with front loader and backhoe, long term project #56
nice work! BTW, as you were pulling it all apart, do you recall details of the Oil Pressure Switch Sensor. I need a mew one here i the UK for my TX2160 and cannot locate the part number. I have not workshop manual either!
   / TX 2160F, with front loader and backhoe, long term project #57
Re: Spool valve and PTO pump question
A bit of an update, things are progressing slowly, I am waiting on a gasket set coming from Europe
Hi, can you share where you find this gasket set? I have the same problem (finding gaskets) for my iseki tx1500, many thanks.
Hi, I have had a look and there is not much information on the pressure switch, try smalltractors.co.uk they had plenty of bits and peices when I gave them a shout, or handy compacts on ebay,
Part numbers are, 5663-021-556-00 and 5661-066-112-00, good luck taking that anywhere and getting any joy though.
   / TX 2160F, with front loader and backhoe, long term project #60
Any work done on the backhoe?
I need to start a project soon to connect some custom-made backhoe (excavator?) onto my tx1500. Yours also looks like non-standard, so i am really curious how it is (supposed to be) connected...?
thx M.
UNUSED FUTURE 12" HYD AUGER (A52706)
UNUSED FUTURE 12"...
2000 FORD F-650 SUPER DUTY (A58214)
2000 FORD F-650...
UNUSED FUTURE 350 HYD BREAKER HAMMER (A52706)
UNUSED FUTURE 350...
2021 Boss 990 Fuel Trailer, VIN: 1F9BT1028MB503652, Honda GC 160 Gas Fuel Pump, Tandem Axle, GVWR: (A59076)
2021 Boss 990 Fuel...
2020 DRAGON ESP...
5011 Ford F-550 (A55973)
5011 Ford F-550...
