TX 2160F, with front loader and backhoe, long term project
   / TX 2160F, with front loader and backhoe, long term project
Well the 3 point linkage issue has now been resolved and my understanding of the hydraulics is a little better now too, I can now in the future get my head around how the spool valve is piped in,
Pipework to suit the manifold I had to get the 3 point linkage working only,
Untitled by chrismac2012, on Flickr
3 Point linkage set bought and fitted, some issues when fitting but got it all together, the upper swivel brackets did not fit so I ended up using the existing,
Next purchase is going to be a rotovator, give the little machine something to work with.
Been a little while since I have done much but I took the sump off and used the origional gasket and some rtv silicon and that seems to have cured the small leak I had, it was a good chance to check the bearings for my own peice of mind when I was in there,
I have started making a rear box
I have another wee project to keep me busy a godiva fire pump with a coventry climax engine.
Chris
   / TX 2160F, with front loader and backhoe, long term project #54
Hi Darryl, thanks for the comments its been a steep learning curve, yes thats one I used to own, I have a bit of a collection now,
Chris
   / TX 2160F, with front loader and backhoe, long term project #56
nice work! BTW, as you were pulling it all apart, do you recall details of the Oil Pressure Switch Sensor. I need a mew one here i the UK for my TX2160 and cannot locate the part number. I have not workshop manual either!
   / TX 2160F, with front loader and backhoe, long term project #57
Re: Spool valve and PTO pump question
A bit of an update, things are progressing slowly, I am waiting on a gasket set coming from Europe
Hi, can you share where you find this gasket set? I have the same problem (finding gaskets) for my iseki tx1500, many thanks.
Hi, I have had a look and there is not much information on the pressure switch, try smalltractors.co.uk they had plenty of bits and peices when I gave them a shout, or handy compacts on ebay,
Part numbers are, 5663-021-556-00 and 5661-066-112-00, good luck taking that anywhere and getting any joy though.
   / TX 2160F, with front loader and backhoe, long term project #60
Any work done on the backhoe?
I need to start a project soon to connect some custom-made backhoe (excavator?) onto my tx1500. Yours also looks like non-standard, so i am really curious how it is (supposed to be) connected...?
thx M.
UNUSED FUTURE...
2025 JMR 40in Single Cylinder Brush Grapple Mini Skid Steer Attachment (A56857)
2025 JMR 40in...
NEW HOLLAND T4.75 TRACTOR (A52707)
NEW HOLLAND T4.75...
1667 (A57192)
1667 (A57192)
FORD F550 SUPER DUTY SERVICE TRUCK (A52707)
FORD F550 SUPER...
JOHN DEERE ZERO TURN LAWN MOWER (A54756)
JOHN DEERE ZERO...
