two wheel powertrac
  • Thread starter washita
  • Start date
/ two wheel powertrac #1
W
washita
Guest
who will be the first member to build a two wheel powertrac to compliment their four wheeled machine, would make a nice sunday afternoon conversation piece if nothing else
/ two wheel powertrac #2
Power-Trac motorcycle with hydraulic steering and hydraulic all (both?) wheel drive and front-mounted quick-attach...Hmmm...what could possibly go wrong?
/ two wheel powertrac #6
WARNING! My security software blocked an attack from that web site!
/ two wheel powertrac #8
I am pretty security minded and I have no issue. It was linked out of gizmodo which is quite reputable in not putting up malware sites.
/ two wheel powertrac #10
Some large entities subscribe to a blackhat list that can often have reasonable sites on it. I used to wrestle with it at a prior employer. I think that some sites co-hosted with others would get tagged with the address and blocked.
I had no issues getting in, FWIW.
/ two wheel powertrac #11
Norton Internet Security showed an alert: "Norton has blocked an attack from a malicious DNS server!" A malicious domain name server might switch the IP address to point to a modified or subverted copy of the web site you were seeking.
I just accessed the site again an received the same alert message. Unless your computer is using an Intrusion Detection System like the one that is part on NIS, you would not receive an alert or any indication of a penetration attempt. The web site can be access normally.
I suggest you run you virus and spyware scanner as a precaution.
/ two wheel powertrac #12
So I did a deep search.... The link I provided is off of gizmodo, so it has a re-direct. Norton is warning you you are being sent to a page different than the one you clicked. in this case harmless (IMO), but a good detector if you would be asked to change your password illegally or something like that.
How does this work for you Clumber?
http://www.jakessite.com/2005/reece/reece.html
/ two wheel powertrac #13
No alerts with that URL. Glad to see there were no problems with the site.
Intrusion detection / prevention components use a data base of patterns collected from past malicious incidents. It's not a precise science so there are false positives from time to time.
2012 PROCO 130BBL VAC TRAILER (A58214)
2012 PROCO 130BBL...
TAYLOR WAY 962 48" HYD TILLER (A57192)
TAYLOR WAY 962 48"...
(INOPERABLE) GEHL 8K TELEHANDLER (A58214)
(INOPERABLE) GEHL...
HAMM H11 PADFOOT ROLLER (A58214)
HAMM H11 PADFOOT...
BUSH HOG 406-6' ROTARY MOWER (A59823)
BUSH HOG 406-6'...
1997 John Deere 5300 (A60462)
1997 John Deere...
