Two hooks or three??
/ Two hooks or three?? #41
Hey George, I can weld you up some "D" rings if you want. In the attached picture we were going to change the 2" steel pin used for pulling (located directly above the rear axle on the frame) with a larger "D" ring because another of these trucks kept pulling the brackets off the frame that holds that 2" pin. I don't recall now, but I think the "D" ring itself weighed about a hundred pounds and would ring like a bell if you hit it with a sledge. But, there again, I sort of doubt a BX would pull this truck out if it got stuck. :D
/ Two hooks or three?? #42
i also welded one in side the bucket center. the top center watch what you load you'll bend the top. reinforcing it sounds like a good idea on of the guys said above.
