Twisted PTO Shaft
/ Twisted PTO Shaft
I just wanted to let everyone know the conclusion to this story. I was not able to get any replacement parts from Rhino. I was told the mower was built between 1964 and 1979. I checked a couple of local Rhino dealers with no luck either.
So, I decided to convert this thing to a shear pin set-up. I went to Tractor Supply and picked up a new PTO shaft and a hand full of 1/2" bolts. Yesterday I got out there with my angle grinder and drill press and got busy. I was able to set the drill press directly on top of the shaft and drilled a 1/2" hole in it. Then I cut off the necked down section leaving only the 1 3/8" diameter shaft. Or at least I thought it was 1 3/8" diameter. It was just a hair bigger than that and wouldn't fit inside the new PTO shaft connection. Spent the next hour or so grinding the outside of the shaft down to fit. I finally got it and the PTO shaft spins nicely on the shaft. I stuck a bolt in the hole, hooked everything up, and jumped on the tractor. I took it out back and did some brush hogging for about half an hour. Everyting is working great! I even tested the shear pin/bolt and got it to snap on a 3" tallow stump.
I want to thank everyone for their input and help with my problem.
Happy Hoggin!
JB
2016 New Holland Boomer 47 (A60462)
2016 New Holland...
2015 GENIE GTH-1056 TELESCOPIC FORKLIFT (A59823)
2015 GENIE...
2012 Acura TL Sedan (A59231)
2012 Acura TL...
UNUSED INDUSTRIAS AMERICA HYD POST PULLER (A60430)
UNUSED INDUSTRIAS...
SANY SY225C9C5KL EXCAVATOR (A59823)
SANY SY225C9C5KL...
2021 Polaris Ranger Electric Utility Bed UTV (A56859)
2021 Polaris...
