turnoffs and downsides to old iron-survey
   / turnoffs and downsides to old iron-survey
I know you could get the ford 5000 with a narrow front.. they ran thru 75.. though i don't know if the narrow front was offered for the entire line.. but I would think at least thru 68' for that model anyway.. if not later..e tc.
I've looked at a dc and VAC... Have you driven either? if so... comments?
Soundguy
   / turnoffs and downsides to old iron-survey #42
KYErik said:
I love my 1943 Case SC (roughly the same size/hp as the International model H). Its a very functional family heirloom. It was my one of my great garndfather's first tractors when he retired the horses. I really like my tricycle front end. It turns so much sharper than the wide front tractors when I am mowing and raking hay and I can squeeze the front end into a little crack between other equipment in my pole barn. My property has gentle rolling hills so rollovers aren't an issue.
Upsides- built heavy and strong, easy to make routine adjustments (clutch free play, etc.), the option to buy a tricycle from end if you want one
Downsides- Get used to rust and frozen bolts, lack of power steering and power brakes, rotted out radiators, engine parts are sky high from the dealer (Over $100 just for the ring gear, $130 for water pump rebuild kit) Aftermarket engine rebuild parts are getting scarce for my tractor, it would cost about 1K to overhaul the engine if I ever get tired of the blue smoke that protects me from getting West Nile ;-)
Anyone know when the last tricycle type tractors were made? Late 70's?
Deere offered narrow fronts as late as 1982 on the last of the 40 series. I've seen a 4040 NF. When mounted corn pickers disappeared, so did the need for big tractors with narrow fronts, for the most part. Massey dropped narrow fronts when the 100/1000 series ended in 1975. Not sure about any others.
   / turnoffs and downsides to old iron-survey #43
Soundguy- sorry, can't help you there. I haven't ever driven a VAC or a DC. The DC is supposed to be = to the Farmall M, the VAC is the smallest tractor Case made in that era
2010 CATERPILLAR 924H WHEEL LOADER (A60429)
2010 CATERPILLAR...
2006 Ford F-150 Lariat (A57148)
2006 Ford F-150...
2021 CATERPILLAR D5 LGP HIGH TRACK CRAWLER DOZER (A60429)
2021 CATERPILLAR...
2408 (A60432)
2408 (A60432)
2011 CATERPILLAR 279C SKID STEER (A60429)
2011 CATERPILLAR...
Box of Transport Ratchet Straps (A59230)
Box of Transport...
