Turning Radius with Mower?
/ Turning Radius with Mower? #1
Wingsy
Mocksville, NC
Kubota BX25
Hello everyone. Total tractor newbie here with some newbie questions.
I've got a Kubota BX25 with a New Holland flail mower I just attached to it (model 918L, 50"). I believe I have it hooked up and adjusted properly. It's pretty firmly attached to the tractor. Hardly any sway when I tug on the lifted mower. I've only tested it out by mowing about 100 feet. Seems to be working fine. My question is, just how much of a turn should I be able to make with this thing while mowing? I'm guessing not much at all. It seemed to resist turning with what little turning I tried during testing. Is this thing going to be good for pretty much just mowing in a straight line?
Next Q: Can I replace all the cotter pins on the 3-pt hitch with hairpins?
Another: How much of an incline should I be able to safely mow, back & forth, not up & down? It seems even a little bit of a tilt and I'm getting nervous. While I'm asking, how much of an incline can I mow going up & down?
One more: I've had to cut the drive shaft to the mower, and with the mower on the ground and adjusted level, I have 3.5 inches of the inner plastic sleeve showing under the outer sleeve. The shafts themselves are cut 3/4" longer than the sleeves. Is this about right?
2016 WANCO WTSP PORTABLE ARROW BOARD (A60429)
2016 WANCO WTSP...
2019 GMC SIERRA HD 3500 (A63569)
2019 GMC SIERRA HD...
2018 Volvo VNL T/A Sleeper Cab Truck Tractor (A61573)
2018 Volvo VNL T/A...
2022 EZ-GO ELITE...
2023 Unverferth 3PT 6 FT Perfecta Field Cultivator (A63688)
2023 Unverferth...
2007 Chevrolet Express 2500 Cargo Van (A61573)
2007 Chevrolet...
