turning light quirkiness BX22
/ turning light quirkiness BX22 #1
FamilyFarm
Platinum Member
Crane, MO
Kubota L4740HST, Kubota RTV 1140 Camo
With the switch in the off position, one of my turn signal lights blinks while the other stays lit. Is this a wiring problem or some built in system to warn me of bulb malfunction? Anyone else had this happen? I haven't had time to check it out. Loose wire maybe? Switch problem? THANKS, Terry
/ turning light quirkiness BX22 #3
I've read where some of the guys have gotten water in the switch and has caused lights to come on while the switch is in the off position. I think they were saying to take the switch apart, dry it out, and then put Vaseline in it to act as a lubricant and keep water from puddling in there and acting as a conductor.
I haven't had that problem with mine yet though. /forums/images/graemlins/smirk.gif
/ turning light quirkiness BX22 #4
KMC Peanut Inverter Blades (A64119)
KMC Peanut...
2015 Ford Escape 4WD SUV (A61574)
2015 Ford Escape...
UNUSED WOLVERINE HYD STUMP GRINDER (A64281)
UNUSED WOLVERINE...
Deutz Engine Manuals (A63117)
Deutz Engine...
2020 FORD F-150 XL EXTENDED CAB TRUCK (A64276)
2020 FORD F-150 XL...
Kubota L175 Tractor (A62613)
Kubota L175...
