Turn which way?
/ Turn which way? #1
Haroldv
Michigan Thumb
B2910
Any one ever have to rewire their turn signals? Mine on my 2910 work the opposite of what they should. When I turn on the left turn signal the right one flashes. The in dash indicator flashes correctly. What is the trick to remove the plastic cover under the strreing wheel?
Harold
/ Turn which way? #2
Oh boy, Harold. I hate that job because I always worry about breaking those little tabs that hold things together when you have to pry them loose. You can pry out the "easy checker" or instrument panel. If you need to take the plastic cover loose, there's one big screw, top center (behind the fuel cap), then 2 tabs to pry loose on each side. Then you can't raise it enough to get in there without punching the roll pin out of the throttle lever to remove the lever. If it's still in warranty, I'd have the dealer do it; however, I had to take mine loose to get into there and change the cigarette lighter I had the dealer install when I bought the tractor because, like a dummy, I washed the tractor, got water in the cigarette lighter, and let it corrode.
Bird
/ Turn which way? #3
You might be able to swap the wires under the rear fender where they attach to the lights. There are barrel connectors. I don't know if the wire lengths make them interchangable or not.
High techie, reciently founded a startup company and struggling for tractor time.
/ Turn which way? #4
Re: Turn which way? Warranty Issue?
I would think that most, if not all, B2910s would still be under warranty. If this is true for yours then I believe that I would have the Kubota shop fix the problem. This way you don't risk tearing up something else and voiding part of the warranty.
Kelvin
/ Turn which way? #5
I thought they were only flashers. Do you actually use turn signals on your tractor? I know in California we are often criticized for not using turn signals and in this case I would be guilty. When driving on public roads, flashers and hand signals are all you get out here. Its pretty rare that tractors pass cars unless you have a mighty TC18 of course. Rat...
/ Turn which way? #6
I'm with you, Rat. All I have on my L3600 is my right and left arms which I proudly stick out when I'm going to turn. Not the best system but it does avoid all those tedious wiring problems!
/ Turn which way? #7
Rat & Tony, believe it or not, I really do use the turn signals on my B2710, and fortunately, mine work right.
Bird
/ Turn which way? #8
That's certainly true if the dealer is accessible. I personally find that by the time I drag my tractor to the dealer (and they are only 5 miles away) and go through the motions, I can fix it faster myself if it's something small.
/ Turn which way? #9
Bird,
With a smaller tractor, what do you need the turn signals for? Do you drive down the road with it? Cliff
I'm moving up to a 4710 or 5205!
/ Turn which way? #10
Yep, Cliff, I wouldn't have any use for the turn signals if I didn't drive it on the road occasionally. But when I get out on the farm-to-market roads around here to go to neighbors' or my brother's place, I turn on the headlights and flashers (and of course I have the SMV placard on the tractor). With the flashers on, turning on a turn signal causes the opposite light to stay on steady and the turning direction to flash.
Of course, there is admittedly so little traffic out here that if the tractor didn't have turn signals, they probably wouldn't be missed.
Bird
/ Turn which way? #11
Bird,
I don't think I could drive my little 4100 up and down a road, I don't think I would feel safe unless I was on a bigger tractor. But your tractor is a bit bigger than mine.
/ Turn which way? #12
I didn't say I felt safe, Cliff./w3tcompact/icons/laugh.gif When I had the B7100, it had a top speed of about 9 mph and now the B2710 has a top speed of about 12 mph, and I probably wouldn't drive on the road either if it weren't for the fact that the farthest I drive it on the road is less than 8 miles, and I might see 4 or 5 other vehicles on the road in that distance. I wouldn't do it if there was enough traffic to amount to anything.
Bird
/ Turn which way? #13
Bird,
Well since there isn't many cars, I can see why you do it. My road is so busy and people drive so fast that I don't even like to drive it in my truck! Cliff
Big John Semi Trailer (A65640)
Big John Semi...
Star (A64557)
Star (A64557)
2025 Mini Bucket Excavator Attachment (A64553)
2025 Mini Bucket...
2022 GMC Sierra 2500 HD 4x4 Crew Cab Pickup Truck (A64556)
2022 GMC Sierra...
Large Cow (A64557)
Large Cow (A64557)
2008 Case CX240B Hydraulic Excavator (A64194)
2008 Case CX240B...
