Tires turf tires
/ turf tires #1
Anonymous Poster
Epic Contributor
can you put turf tires on the fwd models.. I know you lose some of the traction with turf tires.. but you should not be doing damage to lawn care.. for snow removal most the time 4-6" is max at one time and I'm guessing turf tires would do just as good
/ turf tires #2
ket,
I run truf tires year round,and when the winter snow arrives I put tire chains on the back rear tires only,plus when mowing steep slopes.
/ turf tires #3
If you are going to use your tractor on turf, turf tires are a must. You loose some traction as compared to ags. Firestone has turf tired that will fit in a lot of cases http://www.firestoneag.com/default.asp. The big concern when changing tires on a 4WD is to maintain the rolling circumference ratio of the front tires to the back tires. Roger Scotty can probably explain this a lot better than me. He just about wrote the book over at the old club. If you change the ratio a lot you risk damaging the drive train. There are two ways to go with turfs. You can get the extra wide turfs which will require new wheels or you can get turf tires which are about the same size as the original ags and which mount on your origanal wheels.
Chris
/ turf tires
I went with the same size replacement turf and put 16" truck tires on my front. Haven't had any problems, but haven't has much snow here in the East this winter. Even replacing ins same size is expensive without adding new wheels and the extra price for wide tires.
2017 Wacker Neuson LTV6 Towable Light Tower (A56857)
2017 Wacker Neuson...
2012 DRAGON 130BBL VAC TRAILER (A60736)
2012 DRAGON 130BBL...
New/Unused Pallet of 8 Binders and 16 Chains (A61166)
New/Unused Pallet...
2007 International 7400 T/A Altec D4050A T 50ft Insulated Digger Derrick Truck (A60352)
2007 International...
2013 Nissan Altima Sedan (A61569)
2013 Nissan Altima...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
